PPP to vrf
Hi guys,
I'm struggling with a scenario. There's a centralized server farm with several virtual instances of a software. Different customers should get access only to their instance. Normally the customer has an existing DSL connection through his provider.
I want to realize this scenario through a PPP connection initiated by a customer computer. Is it possible to terminate these PPP connections on a router in front of the server farm in different vrf's? This would ensure that the customers are seperated and even could use overlapping address space.
Can this solution work? Do I have to use virtual-templates?
Thanks in advance for your replies.
Mike
1 REPLY
Re: PPP to vrf
I mean that can work. I use this with one PRI to collect ISDN calls in different vrf?s. You have to set the vrf instance on the different dialer interfaces. I have a caller identification to bind the caller to the dialer interfaces, which are in different vrf?s...
99
