12-05-2005 10:57 PM - edited 03-03-2019 11:09 AM
I have to set up pppoe on ADSL link. The steps are:
modem connected, pppoe, pap authentication, and the last - external ip adress from provider.
I have tried it on Cisco 871 and Cisco 806 - both tries had same error in debug log.
Here is my config and part of debug
Using 1605 out of 131072 bytes
version 12.3
no service pad
no service dhcp
hostname burshtyn806
enable secret xxx
enable password xxx
username pbivf password xxxxx
clock timezone UKR 2
clock summer-time UKRS recurring last Sun Mar 3:00 last Sun Oct 3:00
ip subnet-zero
no ip domain lookup
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0
ip address 10.18.80.3 255.255.254.0
no ip route-cache
ip tcp adjust-mss 1452
no ip mroute-cache
no cdp enable
interface Ethernet1
no ip address
no ip route-cache
no ip mroute-cache
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap
ppp pap sent-username xxx@provider.net password 0 xxxxxx
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
access-list 1 permit 0.0.0.0 255.0.0.0
dialer-list 1 protocol ip permit
no cdp run
snmp-server community XXXXX RO
snmp-server enable traps tty
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
access-class 182 in
exec-timeout 0 0
no login
transport input telnet
scheduler max-task-time 5000
end
and here is the log
PPPoE:
PPPoE protocol events debugging is on
PPPoE control packets debugging is on
PPP:
PPP protocol negotiation debugging is on
VPN:
VPDN events debugging is on
*Mar 1 20:20:43.978: Vi1 PPP: Using dialer call direction
*Mar 1 20:20:43.978: Vi1 PPP: Treating connection as a callout
*Mar 1 20:20:43.978: Vi1 PPP: Phase is ESTABLISHING, Active Open
*Mar 1 20:20:43.998: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar 1 20:20:44.050: Vi1 LCP: State is Open
*Mar 1 20:20:44.050: Vi1 PPP: Phase is AUTHENTICATING, by both
*Mar 1 20:20:44.054: Vi1 PAP: Using hostname from interface PAP
*Mar 1 20:20:44.054: Vi1 PAP: Using password from interface PAP
*Mar 1 20:20:44.054: Vi1 PAP: O AUTH-REQ id 1 len 35 from "myusername@provider.net"
*Mar 1 20:20:44.098: [0]PPPoE 59020: I R:0011.5c31.311b L:000a.f409.22df Et1
C0 21 05 03 00 04
*Mar 1 20:20:44.102: Vi1 LCP: I TERMREQ [Open] id 3 len 4
*Mar 1 20:20:44.102: Vi1 LCP: O TERMACK [Open] id 3 len 4
*Mar 1 20:20:44.102: Vi1 PPP: Sending Acct Event[Down] id[B9A]
*Mar 1 20:20:44.106: Vi1 PPP: Phase is TERMINATING
*Mar 1 20:20:44.158: PPPoE : Shutting down client session
*Mar 1 20:20:44.162: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Mar 1 20:20:44.170: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Please, help!
Solved! Go to Solution.
12-06-2005 12:09 AM
12-06-2005 12:09 AM
you might want to try:
ppp authentication pap callin
HTH,
GP
12-06-2005 12:13 AM
YES!!! IT WORKS, IT REALLY WORKS!!!
Thank you very much!!!
09-11-2007 05:02 AM
We have a very similar configuration. our only difference is , we need dial backup to work using async1. Can you help with this?
