Community Member
PPPOE Configuration Problem
ISP provided PPPOE connection I have changed the bridge mode in ISP modem and my lap is directly connected to ISP modem and then I have configured the PPPOE in my LAPTOP that time I am able to access the Internet. I am trying to connect my cisco 1842 router to ISP modem and I am configuring the PPPOE in that router but the internet link is not coming up please any one help me .
interface Ethernet0/1
no ip address
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip nat outside
ip mtu 1492
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username cisco password cisco1
ip nat inside source list 1 interface Dialer1 overload
ip route dialer1
access-list 1 permit any any
But I didn't configure the below
vpdn enable
no vpdn logging
vpdn-group 1
protocol pppoe
Re: PPPOE Configuration Problem
add those commands
vpdn enable
no vpdn logging
vpdn-group 1
protocol pppoe
while i think in newer verion u dont need to enable the vpdn, but try it
also use the following link to help u in ur config
please, rate if helpful
Have you tried;
Debug ppp negotiation
This will show you the PPP neg and gives info on what is going on.
Community Member
Hi All
I am not sure the Authentication whether it is PAP or CHAP , So I have configured both
enable vpdn
PPP Authentication papa chap
Chap hostname ******
Chap password ******
Ppp PAP sent username ******** password ********
Now the link is up and running fine. Thanks for all.
cool :)
please, rate the helpful post
