03-26-2007 11:24 PM - edited 03-03-2019 04:18 PM
Why my pppoe connection always disconect?
bellow is my config and debug :
ip sla monitor 1
type dns target-addr http://www.google.com name-server 202.188.0.133
timeout 2000
threshold 4
frequency 15
ip sla monitor schedule 1 life forever start-time now
vpdn enable
isdn switch-type basic-net3
track 1 rtr 1 reachability
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
lifetime 43200
crypto isakmp key xxx address 58.x.x.99
crypto isakmp key xxx address 218.x.x.146
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 15 15 periodic
crypto ipsec transform-set CMSET esp-3des esp-md5-hmac
crypto ipsec df-bit clear
crypto map CMMAP 10 ipsec-isakmp
set peer 58.26.35.99
set peer 218.208.36.146
set transform-set CMSET
match address 110
interface Loopback0
ip address 219.93.x.x.255.255.255
crypto map CMMAP
interface BRI0
description $BACKUP_INTF_Ethernet0_TRACK_1$
no ip address
encapsulation ppp
dialer rotary-group 0
dialer-group 1
isdn point-to-point-setup
crypto map CMMAP
interface Ethernet0
description ***PPPOE***
bandwidth 1024
no ip address
ip tcp adjust-mss 1452
shutdown
half-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface FastEthernet0
ip address 10.106.163.1 255.255.255.0
speed auto
interface Dialer0
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 500 either
dialer string 1525
dialer hold-queue 10
dialer load-threshold 1 either
dialer-group 1
ppp pap sent-username icourtsn@fixed password xxx
ppp multilink
crypto map CMMAP
interface Dialer1
description *** For ADSL Dialup ***
encapsulation ppp
dialer pool 1
dialer idle-timeout 14400 either
dialer-group 1
ppp authentication pap callin
ppp pap sent-username courtsrn@streamyx password 0 tmnet123
crypto map CMMAP
ip local policy route-map SDM_BACKUP_RMAP_1
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 Dialer0 200
ip route 202.x.x.133 255.255.255.255 Dialer1
no ip http server
no ip http secure-server
ip nat inside source route-map SDM_RMAP_1 interface Dialer1 overload
access-list 10 remark *** To disable IPS for VPN traffic ***
access-list 10 deny 10.106.0.0 0.0.7.255
access-list 10 deny 100.1.1.0 0.0.0.255
access-list 10 permit any
access-list 100 permit ip any host 202.188.1.5
access-list 100 permit ip any host 202.188.0.133
access-list 110 permit ip 10.106.163.0 0.0.0.255 10.106.0.0 0.0.7.255
access-list 110 permit ip 10.106.163.0 0.0.0.255 100.1.1.0 0.0.0.255
access-list 120 remark *** To disable NAT for VPN traffic ***
access-list 120 deny ip 10.106.163.0 0.0.0.255 10.106.0.0 0.0.7.255
access-list 120 deny ip 10.106.163.0 0.0.0.255 100.1.1.0 0.0.0.255
access-list 120 permit ip 10.106.163.0 0.0.0.255 any
dialer-list 1 protocol ip permit
snmp-server community CMSNMP RO
snmp-server enable traps tty
route-map SDM_BACKUP_RMAP_1 permit 1
match ip address 100
set interface Dialer1
route-map SDM_RMAP_1 permit 1
match ip address 120
control-plane
line con 0
login
line aux 0
line vty 0 4
exec-timeout 600 0
logging synchronous
login
ntp clock-period 17179941
ntp server 192.228.128.20 prefer
end
debug pppoe event:
Mar 27 13:28:37: PPPoE : Shutting down client session
Mar 27 13:28:37: [0]PPPoE 566: O PADT R:0090.1aa0.6100 L:0004.dc0d.c11f Et0
Mar 27 13:28:37: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
Mar 27 13:28:37: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Mar 27 13:28:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
03-27-2007 09:50 PM
Please run "debug ppp authentication"
and "debug ppp negotiation" and redirect
that to syslog server (in case your disconnect is intermittent). If you see
no authentication failures when disconnected,
then try to run PPPoE config only to make sure there is no collision with other features you're running.
HTH,
OW
