Community Member
PPPoE in Cisco 1841 router with dynamic ip address
Hello
can anybody please help me.
we are implementing new Cisco 1841 router in our network, previously we are having Wimax internet connection, now we need this router to be configured as PPPoE client that get dynamic IP address form the PPPoE server, can any body give me complete configuration to overcome with this problem, assuming that the ISP provide us with this information
1. PVC 0/50
2. PAP used as authentication type
3. user name and password
Note : there is no ATM interface in this router.
so please your urgent response will help us get ride of this. thank you
Hall of Fame Super Silver
Re: PPPoE in Cisco 1841 router with dynamic ip address
Hello Ala,
use the following doc
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080126dc0.shtml
remenber to define the ACL for interesting traffic
example:
interface Dialer1
description PPPoverETHERNET
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username username password xxx
Hope to help
Giuseppe
Community Member
Dear Giuseppe
thank you for your effort
but i've tried and it dosn't work
when iam pinging to address it shows me msg like this
"Unrecognized host or address, or protocol not set
Can you advise please with my thanks
Silver
can you paste your config file
Community Member
User Access Verification
My router#show running-config
Building configuration...
Current configuration : 1827 bytes
version 12.4
hostname falcon
boot-start-marker
boot-end-marker
enable secret xxx
enable passwordxxx
no aaa new-model
resource pol
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip routing
no ip cef
no ip dhcp use vrf connected
no ip domain lookup
vpdn enable
vpdn ip udp ignore checksum
vpdn-group 1
request-dialin
protocol pppoe
interface FastEthernet0/0
description ADSL LAN Interface
ip address 10.10.10.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip route-cache
no ip mroute-cache
speed auto
half-duplex
no cdp enable
no mop enab
interface FastEthernet0/1
description ADSL WAN Interface
no ip address
no ip unreachables
no ip proxy-arp
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
description PPPoverEthernet dial interface
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname alaeldien
ppp chap password 0 4576jfhffh
ppp chap refuse
ppp pap sent-username fsecuri@eim.ae password 0 4576jfhffh
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list acl1 pool pool1
access-list 1 permit 10.0.2.0 0.0.0.255
access-list 1 permit 10.0.0.0 0.255.255.255
dialer-list 1 protocol ip permit
snmp-server community public RO
no cdp run
control-plane
line con 0
line aux 0
line vty 0 4
password xxx
login
end
Hello Ala,
a router for routing needs ip routing
you have:
no ip routing
no ip cef
I strongly recommend you to turn on ipv4 unicast routing with
ip routing
ip cef
in global config mode
Hope to help
Giuseppe
2245
