Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
PPPoE issue on 2801
I have a new 2801 that uses both a T1 via S 0/2/0 and a DSL modem in transparent bridge mode via FE 0/1. The T1 works fine, however I can't get any packets to go out the DSL interface. FE 0/1 is configured to use a PPPoE connection, and it appears to be up and have an ip, however if I try to send packets out that interface, nothing goes out. I've tried by using a policy route-map and also by simply changing the default route to point to that interface.
I know the interface is up from show interfaces Dialer 1. Any ideas on why I can't send/receive packets through this interface?
Here is the config:
router#show run
Building configuration...
Current configuration : 4753 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
boot-start-marker
boot system flash c2801-ipbasek9-mz.124-8.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret xxx
no aaa new-model
resource policy
clock timezone MDT -7
clock summer-time MDT date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
ip name-server 198.x.x.2
ip name-server 198.x.x.22
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
ip address 199.104.x.x.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $FW_OUTSIDE$$ETH-LAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no mop enabled
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial0/2/0
ip address 204.228.x.x.255.255.252
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip route-cache flow
interface Dialer1
description Qwest DSL
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username username password 7 password
ip route 0.0.0.0 0.0.x.x.228.133.45
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
access-list 111 permit tcp any any eq www
no cdp run
route-map toDSL permit 1
match ip address 111
set interface Dialer1
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
password xxx
login
line aux 0
password xxx
login
line vty 0 4
exec-timeout 30 0
privilege level 15
login local
transport input ssh
line vty 5 15
privilege level 15
login local
transport input ssh
scheduler allocate 20000 1000
ntp clock-period 17178103
ntp update-calendar
ntp server 198.60.22.240 source Serial0/2/0
end
VIP Purple
Re: PPPoE issue on 2801
I have made a couple of additions/amendments to your config, can you implement those and check if it makes a difference ? Changes are marked with an arrow -->
version 12.4
no service pad
boot-start-marker
boot-end-marker
enable secret 5 $1$EWDt$pvWzeNhilneb/EUJosxlv0
no aaa new-model
resource policy
no ip source-route
ip cef
no ip bootp server
ip name-server 198.60.22.2
ip name-server 198.60.22.22
ip address 199.104.124.210 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
pppoe enable
no mop enabled
ip address 204.228.133.46 255.255.255.252
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip route-cache flow
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
--> ppp authentication pap callin
--> ip route 0.0.0.0 0.0.0.0 Dialer1
--> dialer-list 1 protocol ip permit
no ip http server
no cdp run
control-plane
line con 0
password 7 05280E16255E41594F
login
line aux 0
password 7 106D010001051D5B5A
login
line vty 0 4
exec-timeout 30 0
privilege level 15
login local
transport input ssh
line vty 5 15
privilege level 15
login local
transport input ssh
ntp update-calendar
end
HTH,
GP
GP, I applied the changes you suggested, yet still can't get any traffic via the PPPoE connection.
I can ping and traceroute from the router to anywhere with the default route set to Dialer1 (the DSL), or S 0/2/0 (T1).
But from any device connected either directly to the router or on the other side of the firewall, all traffic stops as soon as I set the default route to Dialer1.
I know the PPPoE is up via show ip interface Dialer 1.
I opened a case with Cisco about this. They said it was my firewall, however, I connected a laptop direct to FE 0/0 (where the firewall normally connects) and set the default route to the DSL (Dialer1). I could ping anything inside the router, but not past it.
I also tried the MTU adjust fix as per this Cisco doc:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/826/swg/advconf.htm#wp1097132
"If a Cisco router terminates the PPPoE traffic, a computer connected to the Ethernet interface may have problems accessing websites. The solution is to manually reduce the maximum transmission unit (MTU) configured on the computer by constraining the TCP maximum segment size (MSS). Enter the following command on the router's Ethernet 0 interface:
ip tcp adjust-mss mss
where mss is 1452 or less. "
It didn't resolve the issue.
676
