PPPoE on an 871 help
I am trying to set up an 871 router to connect to DSL over PPPoE. As far as I can tell, it is set up correctly, but it doesn't look like it is negotiating properly. I have attached the config as well as the output from the debug ppp negotiation.
Am I missing something in the cofiguration? I am not real familiar with DSL.
Re: PPPoE on an 871 help
why i cant see any NAT deployment
and also why u configure chap and pap
use one
I am not worried about NAT, I can add that once I get the DSL up and running. I configured both PAP and CHAP as I don't know which one Bell South uses, and the tech support person I spoke with couldn't tell me.
this is a sample config use it as refrence
CPE!ip dhcppool MyPool
network 10.0.0.0 255.0.0.0
default-router 10.0.0.1
interface Ethernet0/1
no ip address
pppoe enable
pppoe-client dial-pool-number 1
interface Ethernet0/0
ip address 10.0.0.1 255.0.0.0
ip nat inside
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
ip mtu 1492
ip nat outside
ppp authentication chap callin
pppchap password mysecret
ip nat inside source list 101 interface Dialer0 overload
access-list 101 permit ip 10.0.0.0 0.255.255.255 any
ip route 0.0.0.0 0.0.0.0Dialer0
rate if helpful
interface Dialer1
no ip address x.x.x.x 255.255.255.248
no ppp authentication chap pap callin
ppp chap hostname username@bellsouth.net
ppp chap password password
no ppp pap sent-username username@bellsouth.net password password
no ip route 0.0.0.0 0.0.0.0 74.165.50.205
no ip route 0.0.0.0 0.0.0.0 68.213.6.193
ip route 0.0.0.0 0.0.0.0 Dialer1
and show again
deb ppp neg
deb ppp auth
Do you know if it worked?
140
