PPPoE over L2TPv3
Hi;
we have two routers connected directly to each other through E1 link, first router is 2811 router and the second one is 7200 router.
since 2811 router as I know, is not supporting pppoe server only client; so we need to terminate whatever pppoe packates coming via the fa of the 2811 router in the fa of the 7200 router.
To do this so; I have configured L2TPv3 in the two router and Xconnect in the fa of each router.
the L2TPv3 tunnel is up and established but the pppoe traffic is not being sent to the 7200 router or may be it is sent but not terminated.
aalhousani
2 ACCEPTED SOLUTIONS
Silver
Re: PPPoE over L2TPv3
Yes thts right.....guess its a bit late for this ? Anyways how did it go ?
Silver
Well say you want to terminate 3 L2Tp sessions on E0/1 and connect it back-to-back to E0/2.
Create sub interfaces like this
e0/1.1
encapsulation dot1q 100
xconnect to L2TPv3 peer
e0/1.2
encapsulation dot1q 200
Pls note that at the remote end too you should terminate L2TPv3 on a subinterface.
E0/2.1
pppoe enable
E0/2.2
pppoe enable
Silver
Could you please provide the config. of both routers ?
Hello Jak;
the 2811 router configuration is:-
pseudowire-class fah-test
encapsulation l2tpv3
ip local interface Serial0/0/0
interface FastEthernet0/0
no ip address
no ip mroute-cache
duplex auto
speed auto
pppoe enable group global
no cdp enable
xconnect 195.229.243.198 123 pw-class fah-test
ip address 195.229.243.170 255.255.255.252
no ip mroute-cache
no fair-queue
no cdp enable
The 7200 router configuration is:
vpdn enable
vpdn-group 1
ip local interface POS2/0
interface Serial1/0
ip address 195.229.243.169 255.255.255.252
serial restart-delay 0
no cdp enable
interface POS2/0
description FAH/IWAN-NAD/POP VC4S02
ip address 195.229.243.198 255.255.255.252
encapsulation ppp
ip ospf message-digest-key 1 md5
ip ospf cost 128
crc 32
interface Ethernet3/0
no ip address
no ip mroute-cache
duplex full
xconnect 195.229.243.170 123 pw-class fah-test
interface Virtual-Template1
mtu 1492
ip address 217.284.198.129 255.255.255.128
peer default ip address pool Test
ppp authentication pap
ip local pool Test 217.284.198.130 217.284.198.140
bba-group pppoe global
virtual-template 1
Silver
You may need to xconnect on one FE and terminate the PPPoE on another FE. You cannot terminate the PPPoE on the same interface where the xconnect is present. You could probably connect both the FEs with a crossover
Hi attraqutam;
So, you mean to not enable pppoe in the xconnect interfaces in either 2811 nor 7200 routers, but enable pppoe in differnet ethernet in 7200 and cross connect the xconnect and pppoe ethernets in 7200...
Good I will will try that and come back to you.
Silver
It is work fine as per your recomandation...
if it is possible to terminate more than one L2TPv3 tunnels in the same interface of the router (by using the subinterfaces) coming from different sources? And then cross connect this interface with another interface in the same router and terminate the pppoe for all L2TPv3 tunnels?
I have tried that but the xconnect is not configurable in the subinterface!
Attached is the show version...
Ahmed Al Housani
Silver
Is it supporting encapsulation dot1q in the subinterface ? I think it may be interface limitation.
Thanks;
can you explain more, please?
If that what you mean:-
router(config)#int e3/0.1
router(config-subif)#
router(config-subif)#en
router(config-subif)#encapsulation ?
dot1Q IEEE 802.1Q Virtual LAN
router(config-subif)#encapsulation do
router(config-subif)#encapsulation dot1Q
% Incomplete command.
router(config-subif)#encapsulation dot1Q ?
<1-4094> IEEE 802.1Q VLAN ID
Silver
e0/1.1
e0/1.2
E0/2.1
pppoe enable
E0/2.2
pppoe enable
Thank you very much attrqautam,
The issue I was configuring the xconnect in the e3/0 interface then when I come to configure the same in the subinterface 3/0.1 it will not take it (:
Dear Gautam Attravanam,
I have configure the L2TPv3 in the subinterfaces in both router and the L2TPv3 tunnels comes up.
But when I cross connect the subinterface to another interface and configure PPPoE there, It is glitches to terminate PPPoE traffic.
In the 7200 Router:-
no ip address
no ip mroute-cache
duplex full
no cdp enable
interface Ethernet3/0.1
encapsulation dot1Q 100
no cdp enable
xconnect 200.229.200.166 123 pw-class fah-test
interface Ethernet3/3
no ip address
duplex full
no cdp enable
interface Ethernet3/3.1
In the 2811 router (where the client is initiating the pppoe traffic):-
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
no ip address
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet0/0.1
no cdp enable
xconnect 200.229.200.174 123 pw-class fah-test
Thanks and appriciate your fast respond.
Silver
Are you getting any specific error messages ?
Also hope this link may help you with the config
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a0080080386.html
no errors messages..
by going through the link, I found that pppoe must be configured in the vdpn group!
the issue is when I upgrde the router to have L2TP feature, the pppoe in the new IOS is not configurable in the vpdn-group but in the bba-group.
Did you think this may cuase the issue?
Silver
Is it possible to give the entire PPPoE configuration ? Also is this configuration working when configured on the main interface instead of the sub-interface. Also does creating separate bba groups help instead of using the global group
Sure find below is the pppoe configureation (it is configured only in the 7200 router).
vpdn enable
vpdn-group 1
virtual-template 1
mtu 1492
ip address 200.164.200.129 255.255.255.128
ip local pool Test 200.164.200.130 200.164.200.140
Note the following:-
1) under the vpdn-group (dialin), I can't configure protocol pppoe.
2) It is not possible to configure prorocol pppoe under the subinterface.
3) Yes it was working when configered in the main interface but when also the L2TPv3 is configured in the main interface.
4) regarding creating seperate bba group, I don't try it.
Thanks.
Did you think the IOS maybe cuasing this issue? where I am running 12.4(10) in the router.
Refrence to the link you posted; the pppoe was configured under the vpdn-group where in this IOS pppoe is configured under bba-group!
744
