PPPoE static IP Webserver in DMZ
Hello out there,
ich have a problem with an ASA 5515 configuration. I have 2 internet connections (WAN static,WAN2 pppoe with static ip) . On the pppoe and the outside, i need a webserver in the DMZ The configurstion looks like this:
ASA Version 8.6(1)2
interface GigabitEthernet0/1
nameif outside
security-level 0
ip address 80.80.X.X 255.255.255.248
interface GigabitEthernet0/2
nameif pppoe
security-level 0
pppoe client vpdn group CSP
ip address pppoe setroute
route outside 0.0.0.0 0.0.0.0 80.80.X.X-1 1
nat (DMZ1,outside) source static DMZ1_16 EXT_80.80.X.X service tcp_http tcp_http
nat (DMZ1,pppoe) source static DMZ1_16 EXT_217.91.X.X service tcp_http tcp_http
this nat roule is not accepted because of the public adress assigned to the pppoe interface
access-list outside_access_in extended permit tcp any object DMZ1_16 eq www
access-list pppoe_access_in extended permit tcp any object DMZ1_16 eq www
Access to the Server from external 80.80.X.X is possible
when i use the following nat rule (instead of nat (DMZ1,pppoe)......)
nat (DMZ1,any) source static DMZ1_16 EXT_217.91.X.X service tcp_http tcp_http
I can access the webserver with the IP 217.91.X.X also from inside, but not from the internet (using a mobile phone).
i think the problem is the routing of the default gateway. but i have no idea how to get it work. Normally its ok connecting through ip 80.80.X.X, but we have an old software which connects to the pppoe ip adress, and this can not be replaced right now.
regards
160
