Community Member
PPPOE with SBC and Cisco 1721
I have a 1721 with an ADSL WIC and a 4-port switch. I have it configured and it is connecting to SBC but I'm confused as to the ethernet ports. SBC gives me 5 static IPs. I use one for the Dialer interface. Do I use one for E0, another for E1, etc? Or do I set up DHCP within a VLAN?
Any pointers would be great. The current config is below.
Jon
Router#show run
Building configuration...
Current configuration : 1364 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1
ip dhcp pool napa_dhcp
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 206.13.28.12 206.13.31.12
ip cef
vpdn enable
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
speed auto
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Vlan1
no ip address
interface Dialer1
mtu 1492
ip address SOME.I.P.ADDRESS 255.255.255.248
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname HOSTNAME
ppp chap password 0 PASSWORD
ppp pap sent-username USERNAME password 0 PASSWORD
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
Re: PPPOE with SBC and Cisco 1721
You can use the remaining four either as part of a NAT pool or for making static mappings between public and private ip addresses (say for web, mail access from internet to the inside). On E0 and E1 (if required) you can use RFC 1918 addresses (private space) and then have those addresses nat overload on the dialer interface ip address.
You can use DHCP to assign private addreses on e0 and e1.
PS: Please remember to rate helpful replies!
Community Member
OK. For now, all I want to do is be able for the server on the inside of the net to talk to a server on the outside. So I'm thinking add FE1 as part of the NAT pool.
Any pointers for making static mappings between public and private ip addresses? I've never done that before.
Thanks for your help here! It's made a difference.
Jon
hi
Below mentioned syntax is being used to map the local ip to the global ip (static NAT)
ip nat inside source static
ip nat inside source static { tcp | udp }
Above mentioned command maps based on the PORT No.This is very much vital coz using one public ip u can map to different services hosted on different ports..
ip nat inside source static tcp 192.168.10.1 25 171.69.232.209 25
in the above statement we are mapping only the tcp port of local server to the global address
regds
234
