Bronze
PPTP between CPE and PE
We need to run PPTP between our CE and PE so that we can bill the customer based on their usage. Is it a way to configure PPTP between two routers and if so can someone provide me the related path?
Re: PPTP between CPE and PE
hi arun
are you very much particular about configuring PPTP alone ?
why dont you explore the option of making use of L2TP which also provides the option of accounting at the service provider end.
http://www.cisco.com/en/US/partner/tech/tk827/tk369/technologies_white_paper09186a00800a43e9.shtml
regds
Bronze
hi prem,
we are already using L2TP..
but we need to chk the same can be done by PPTP.. if you have any documents for doing this by PPTP kindly provide the info...
thanks for your reply...
Bronze
hi CAN someone clarify whether PPTP can be created between two routers instead between a client (normally a PC) and a router?? If so pls provide some docsw
147
