Pre-provisioning Nexus5000 with N2K-C2248TP
Hi All,
I have a doubt, we need to include a new Nx5K but i would like to pre-provisioned configuration for not disrupt and renegotiate VPCs with another.
The problem is that I have  N2K-C2248TP model and this hardware is not support....Could it be valid pre provisioning choose 2248T without "P" capability too for this model...could you refer to this information?
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/system_management/502_n1_1/Cisco_n5k_system_mgmt_cg_rel_502_n1_1_chapter4.html#concept_F30E24FA2BFD4946B541E5D7F1A8FC13
COM-SW0-15(config-slot)# provision model  ?
  N2K-B22HP      Fabric Extender 16x10G Module
  N2K-C2148T     Fabric Extender 48x1G 4x10G Module
  N2K-C2232P     Fabric Extender 32x10G Module
  N2K-C2232TM    Fabric Extender 32x10G Module - Zephyr
  N2K-C2248GV+P  Fabric Extender 48x1G 4x10G POE Module
  N2K-C2248T     Fabric Extender 48x1G 4x10G Module
  N2K-N2224TP    Fabric Extender 24x1G 2x10G SFP+ Module
  N55-M16FP      Cisco 16 port Port Fiber Channel Expansion Module 16 x SFP
  N55-M16P       Cisco 16x10G Ethernet Expansion Module
  N55-M16UP      Cisco 16x10G Flexible Ethernet Expansion Module
  N55-M8P8FP     Cisco 8 Port 1/2/4/8G FC + 8 Port 10G Ethernet Expansion
                 Module
  N5K-M1008      Cisco 8 Port Fiber Channel Expansion Module 8 x SFP
  N5K-M1060      Cisco 6 Port Fiber Channel Expansion Module 6 x SFP
  N5K-M1404      Expansion Module 4 x 10GBase-T LAN, 4 x Fiber Channel
  N5K-M1600      Cisco 6-port 10 Gigabit Ethernet SFP Module 6 x SFP COM-SW0-15(config-slot)# provision model  ?
  N2K-C2248T     Fabric Extender 48x1G 4x10G Module <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                 Module
Thanks a lot!!
1 REPLY
In spite of the model was not 100% exactly if configuration match you can preconfigure with other model. For Example if you choose a 24 ports switch you only pre-configure 24 ports and others will be empty.
Regards!
749
