08-28-2014 04:24 AM - edited 03-04-2019 11:38 PM
Hi All,
I learning a route via BGP and OSPF ( via two separate links )
I cant figure out the "best" way to configure the router to prefer the route via OSPF over BGP and if OSPF link fails, it would then use the BGP route.
Its currently learned via BGP
199.199.199.0/32 is subnetted, 1 subnets
B 199.199.199.199 [20/0] via 12.0.0.1, 00:07:19
Routing entry for 199.199.199.199/32
Known via "bgp 1001", distance 20, metric 0
Tag 1000, type external
Last update from 12.0.0.1 00:07:46 ago
Routing Descriptor Blocks:
* 12.0.0.1, from 12.0.0.1, 00:07:46 ago
Route metric is 0, traffic share count is 1
AS Hops 2
Route tag 1000
When BGP is down, Its learned like this:
R5#sh ip route 199.199.199.199
Known via "ospf 1", distance 110, metric 1
Tag 64512, type extern 2, forward metric 2
Last update from 14.0.0.1 on FastEthernet0/1, 00:00:08 ago
* 14.0.0.1, from 14.0.0.1, 00:00:08 ago, via FastEthernet0/1
Route metric is 1, traffic share count is 1
Route tag 64512
Any help would be great.
G
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
Solved! Go to Solution.
08-31-2014 01:00 AM
Hi Graham,
could you check the Forwarding Address of the Type-5 LSA for 199.199.199.199 (show ip ospf database external 199.199.199.199)?
If it is non-zero (not 0.0.0.0), it has to be present as an OSPF internal route in the routing table (RFC 2328 16.4 [3]).
My best guess is that the network the FA belongs to is primarily learned via EBGP as well. If so, just increase the distance for that network in BGP too or (even better, if possible) make sure that the FA is set to 0.0.0.0 at the injecting OSPF ASBR (e.g. passive interface or network point-to-point).
Useful Cisco document: Common Routing Problem with OSPF Forwarding Address
Rolf
09-01-2014 01:40 AM
Ok, cool, we are on the right track ;-)
What we need to accomplish now is that on R5 an OSPF-internal route for the 13.0.0.0 network is installed (1) or that the OSPF ASBR sets the FA to 0.0.0.0 (2).
1) On R5, either change the OSPF- or the EBGP (backdoor) distance for that prefix too.
2) On the OSPF ASBR (where you're redistributing BGP into OSPF), set the 13.0.0.0 interface OSPF passive (if no OSPF neighbor exists on that link) or use network type point-to-point or point-to-multipoint, if possible (in this case you'll have to change the network type on the neighbor(s) of that link as well).
Rolf
08-28-2014 04:31 AM
G
The easy solution would be to change the administrative distance of one of the protocols. Either increase the AD of EBGP so that it is greater than OSPF or decrease AD of OSPF so that it is less than EBGP.
Rick
08-28-2014 04:39 AM
08-28-2014 12:34 PM
Hi @graham smart,
I have something and hope it works for you.
You can create an ACL specifying the route you want to manipulate, then in any of the routing protocols (it will depend in which of them you want to manipulate the AD) you have to tell the protocol that increase or decreased the AD of the route based on the next hop of that route, for example, let's say that you want to manipulate inside OSPF:
# access-list <#> permit x.x.x.x x.x.x.x
# router ospf <process ID>
# distance 10 <next hop> <wildcard mask> <ACL ID>
In your case, it would go something like this:
# access-list 2 permit host 199.199.199.199
# router ospf 1
# distance 19 14.0.0.1 0.0.0.0 2
After this, the router will start to modify the AD "only for that route" based on the next hop that is advertising it.
You can try it in a lab enviroment and then let me know if that could help you.
Rgrds,
Martin, IT Specialist
08-29-2014 06:26 AM
I have tried this, but for some reason it still prefers BGP.
If i use the generic distance setting for ospf and set ALL routes to 19, Then OSPF is the best path.
If I do it JUST for the 199.199.199.199/32 route. It doesnt seem to do anything.
router ospf 1
router-id 14.0.0.2
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
Last update from 12.0.0.1 00:01:58 ago
* 12.0.0.1, from 12.0.0.1, 00:01:58 ago
AS Hops 2
Route tag 1000
sh ip bgp
*> 199.199.199.199/32
12.0.0.1 0 1000 64512 ?
If it set it for distance 19 for OSPF in general,
Known via "ospf 1", distance 19, metric 1
Last update from 14.0.0.1 on FastEthernet0/1, 00:00:11 ago
* 14.0.0.1, from 14.0.0.1, 00:00:11 ago, via FastEthernet0/1
Route tag 64512
Something is going on here where its just not working for that single route?
If i shut down the BGP session, the OSPF route takes over as expected with a AD of 19..
Last update from 14.0.0.1 on FastEthernet0/1, 00:00:15 ago
* 14.0.0.1, from 14.0.0.1, 00:00:15 ago, via FastEthernet0/1
Route tag 64512
Something else must be causeing BGP to me more preferable.
Even If i set BGP to had an AD of 250, Its still more preferable..
What the?
Known via "bgp 1001", distance 250, metric 0
Last update from 12.0.0.1 00:00:42 ago
* 12.0.0.1, from 12.0.0.1, 00:00:42 ago
AS Hops 2
Route tag 1000
Any ideas?
G
08-29-2014 06:51 AM
Hi @graham smart,
Did you specify the ACL with the address you want to manipulate?
access-list 2 permit 199.199.199.199 0.0.0.0
router ospf 1
Without this the "distance" command won't recognize what route is going to manipulate. I'm telling you this because I didn't see it in your example.
Let me know if you did put it.
Rgrds,
08-29-2014 09:16 AM
Indeed, The acl is defined as you said.
If I shut down BGP, I can see the OSPF route with a AD of 19 ( As above )
As soon as BGP comes back, It takes over as the best route, even though it shows and AD of 20.
Route tag 64512
08-29-2014 09:57 AM
Well, maybe you won't like my opinion but ... What the heck!? How is it still believing in an AD of 250 over an AD of 110?
What IOS version are you using and what type of router is this?
Can you provide more output of your configuration?
I think that maybe it's a kind of bug. I've tried this scenario a lot of times and it works for me. :(
Waiting for your responses.
Rgrds,
08-29-2014 10:10 AM
Lol, Yep . Im baffled.
Its a 7200 running a 15 IOS.
Im wondering if the Route metric is 0 on BGP routes and Route metric is 1 on OSPF routes have some kind of play in this problem.
It just doest make sense.
Ill get the full config when i'm back in the office.
08-29-2014 10:13 AM
Ok, but remember that metric is considered after administrative distance is checked.
Rgrds,
08-31-2014 01:00 AM
Hi Graham,
Rolf
09-01-2014 01:06 AM
R5#sh ip ospf database external 199.199.199.199
OSPF Router with ID (14.0.0.2) (Process ID 1)
Type-5 AS External Link States
LS age: 14
Options: (No TOS-capability, DC)
LS Type: AS External Link
Link State ID: 199.199.199.199 (External Network Number )
Advertising Router: 14.0.0.1
LS Seq Number: 80000001
Checksum: 0x2951
Length: 36
Network Mask: /32
Metric Type: 2 (Larger than any link state path)
TOS: 0
Metric: 1
Forward Address: 13.0.0.1
External Route Tag: 64512
I have now set it to be point to point.
LS age: 382
Checksum: 0x2951
Length: 36
Network Mask: /32
TOS: 0
Metric: 1
09-01-2014 01:10 AM
Running Config:
Building configuration...
Current configuration : 1417 bytes
version 12.4
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
archive
log config
hidekeys
ip tcp synwait-time 5
interface Loopback1
ip address 188.188.188.188 255.255.255.255
interface FastEthernet0/0
ip address 12.0.0.2 255.255.255.252
speed 100
full-duplex
interface FastEthernet0/1
ip address 14.0.0.2 255.255.255.252
ip ospf network point-to-point
speed 100
full-duplex
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
router ospf 1
router-id 14.0.0.2
router bgp 1001
no synchronization
bgp log-neighbor-changes
redistribute connected
neighbor 12.0.0.1 remote-as 1000
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip access-list extended BACKUP-PATH
permit ip host 199.199.199.199 any
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
09-01-2014 05:41 AM
Good Job boy!
Rgrds,
09-01-2014 01:40 AM
Rolf
