08-28-2014 04:24 AM - edited 03-04-2019 11:38 PM
Hi All,
I learning a route via BGP and OSPF ( via two separate links )
I cant figure out the "best" way to configure the router to prefer the route via OSPF over BGP and if OSPF link fails, it would then use the BGP route.
Its currently learned via BGP
199.199.199.0/32 is subnetted, 1 subnets
B 199.199.199.199 [20/0] via 12.0.0.1, 00:07:19
Routing entry for 199.199.199.199/32
Known via "bgp 1001", distance 20, metric 0
Tag 1000, type external
Last update from 12.0.0.1 00:07:46 ago
Routing Descriptor Blocks:
* 12.0.0.1, from 12.0.0.1, 00:07:46 ago
Route metric is 0, traffic share count is 1
AS Hops 2
Route tag 1000
When BGP is down, Its learned like this:
R5#sh ip route 199.199.199.199
Known via "ospf 1", distance 110, metric 1
Tag 64512, type extern 2, forward metric 2
Last update from 14.0.0.1 on FastEthernet0/1, 00:00:08 ago
* 14.0.0.1, from 14.0.0.1, 00:00:08 ago, via FastEthernet0/1
Route metric is 1, traffic share count is 1
Route tag 64512
Any help would be great.
G
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
Solved! Go to Solution.
09-01-2014 01:45 AM
Hi Thanks for your update.
With regards to changing stuff on other routers, I don't think this is practical.
It seems that whatever must be done to prefer ospf for this route must be done on R5.
Im starting to think that this isnt even possible ( Other than prefering ALL ospf over bgp as this works , but not really what is wanted. )
09-01-2014 02:23 AM
Oh wait,
Hang on.
Ive put the 13.0.0.0 subnet in the ACL and now to lower the 13 subnet to 19.. and now its working.
Wooooooooooooooooooooooo Thanks :)
R5#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
O E2 199.199.199.199 [19/1] via 14.0.0.1, 00:29:08, FastEthernet0/1
172.200.0.0/32 is subnetted, 2 subnets
B 172.200.0.4 [20/0] via 12.0.0.1, 00:28:42
B 172.200.0.2 [20/0] via 12.0.0.1, 00:28:42
188.188.0.0/32 is subnetted, 1 subnets
C 188.188.188.188 is directly connected, Loopback1
10.0.0.0/30 is subnetted, 3 subnets
B 10.0.0.8 [20/0] via 12.0.0.1, 00:28:42
B 10.0.0.12 [20/0] via 12.0.0.1, 00:28:42
B 10.0.0.0 [20/0] via 12.0.0.1, 00:28:44
89.0.0.0/24 is subnetted, 1 subnets
B 89.0.0.0 [20/0] via 12.0.0.1, 00:15:10
12.0.0.0/30 is subnetted, 1 subnets
C 12.0.0.0 is directly connected, FastEthernet0/0
13.0.0.0/30 is subnetted, 1 subnets
O 13.0.0.0 [19/2] via 14.0.0.1, 00:29:15, FastEthernet0/1
14.0.0.0/30 is subnetted, 1 subnets
C 14.0.0.0 is directly connected, FastEthernet0/1
09-01-2014 06:27 AM
Hello
5+ rating reply Rolf!
res
Paul
08-28-2014 04:53 AM
Hello
I would personally use the bgp backdoor option instead of manipulating the distance metric of bgp itself.
This would advertise 199.199.199.199 in bgp as local route thus increasing its metric to 200.and giving preference to OSPF as metric 110
On the router receiving this route
router bgp xx
network 199.199.199.199 mask 255.255.255.255 backdoor
exit
res
Paul
08-28-2014 05:05 AM
I tried this before, I see its increased the distance to 200, Yet the route still appears in teh routing table as "best" ?
Also, wont I have problems re-advertising the 199.199.199.199 route to the network behind this router? ( As backdoor doesnt re-advertise? )
Known via "bgp 1001", distance 200, metric 0
Tag 1000, type locally generated
Last update from 12.0.0.1 00:00:13 ago
* 12.0.0.1, from 12.0.0.1, 00:00:13 ago
AS Hops 2
Route tag 1000
R5#sh ip route | inc 199.199
B 199.199.199.199 [200/0] via 12.0.0.1, 00:00:58
Am I missing something?
OSPF is 100% advertising it to me.
R5#sh ip ospf database | inc 199.199
199.199.199.199 14.0.0.1 112 0x80000007 0x001D57 64512
G
08-28-2014 06:47 AM
Hello
Just to confirm, The receiving router has two paths to this route:
1) via BGP = metric 20
2) via ospf - metric = 110
Now on the RECEIVING router for this route you've applied the backdoor command to bgp - correct?
res
Paul
08-28-2014 07:14 AM
That is correct.
Details below of backdoor command. It clearly changes the distance for BGP to 200 but doesnt seem to let ospf take the route.
Is there no other method to force a router to use one path over another?
If i change OSPF's AD to 201, OSPF's route appears instead of BGP.
I suppose the problem is that I dont want to change the whole AD of a routing protocol.
I have tried with a route-map inbound to somehow change the weight etc but cant seem to get it working either.
R5#show ip route 199.199.199.199
Last update from 12.0.0.1 01:35:54 ago
* 12.0.0.1, from 12.0.0.1, 01:35:54 ago
AS Hops 2
Route tag 1000
R5#
R5#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R5(config)#router bgp 1001
R5(config-router)#network 199.199.199.199 mask 255.255.255.255 backdoor
R5(config-router)#end
Last update from 12.0.0.1 00:00:03 ago
* 12.0.0.1, from 12.0.0.1, 00:00:03 ago
AS Hops 2
Route tag 1000
06-05-2019 07:09 AM - edited 06-05-2019 07:11 AM
Graham,
While this reply might be a bit late. I just wan't to described how I solve this problem before. If you would like to prefer OSPF to be the first router to be available you should place a lower weight on the BGP router for routes coming from BGP or a higher weight from routes coming from OSPF.
If you check the BGP router you will notice that the routes redistributed from OSPF will have a weight of 0 on BGP RIB, and that the route of from BGP will have 32768. I normally place a higher weight at the redistribution point from OSPF to BGP to be 40,000. Meaning for BGP to always prefer the router sourced from OSPF. With this setup OSPF will be always preferred until it disappears from the routing table at which point the route coming from BGP will be injected. I normally have this situation with MPLS providers.
