Community Member
Priority percent bandwidth not computed accurately
Cisco 3845 running 15.1(4)M2 - allocated bandwidth not showing correctly
interface Serial4/0
mtu 1500
bandwidth 25000
no ip address
encapsulation frame-relay IETF
logging event subif-link-status
logging event dlci-status-change
load-interval 30
dsu bandwidth 44210
serial restart-delay 0
frame-relay traffic-shaping
frame-relay lmi-type cisco
max-reserved-bandwidth 100
hold-queue 300 in
hold-queue 300 out
interface Serial4/0.111 point-to-point
bandwidth 25000
ip address <removed>
no ip unreachables
ip flow ingress
ip flow egress
ip pim query-interval 60
ip pim sparse-mode
ip multicast boundary MCAST_BOUNDARY
no cdp enable
frame-relay class shapeDS3
frame-relay interface-dlci 111
policy-map MPLS-OUT
class QUEUE-1
  priority percent 40
map-class frame-relay shapeDS3
frame-relay cir 25000000
frame-relay bc 250000
frame-relay be 0
service-policy input MPLS-IN
service-policy output MPLS-OUT
sho policy-map interface S4/0.111 output class QUEUE-1
Serial4/0.111: DLCI 111 -
  Service-policy output: MPLS-OUT
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: QUEUE-1 (match-all)
      21270782 packets, 4246609810 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
      Priority: 40% (5000 kbps), burst bytes 125000, b/w exceed drops: 43
Everyone's tags (3)
