Problem Applying QoS Policy to ATM Interface
Greetings i have a Cisco2801 ISR with G.SHDSL HWIC installed, it has the following QoS/ATM configuration at present however when i try to apply the policy to the ATM subinterface it wont stick, we are running 12.4(21)Advanced security, the strange thing is that i dont receive any error messages indicating as to why the policy apply, any suggestions would be much appreciated.
controller DSL 0/1/0
mode atm
line-term cpe
line-mode auto
dsl-mode shdsl symmetric annex B
class-map match-any Voice-Media
match ip dscp ef
class-map match-any Voice-Signalling
match ip dscp cs3
match ip dscp af31
policy-map SDSL-WAN-OUT
class Voice-Media
priority 256
class Voice-Signalling
bandwidth 8
class class-default
set ip dscp default
fair-queue
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
interface ATM0/1/0.1 point-to-point
bandwidth 2048
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
**Trying to insert Service Policy here**
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Problem Applying QoS Policy to ATM Interface
insert the policy under the PPP dialer interface.
Thank you for that, i had tried the same previously but it reported an error stating that there wasnt enough free bandwidth on the link, i forgot to add the "bandwidth" statement under the dialer interface.
All is working now, thank you for your time.
219
