Community Member
Problem Cisco 2801 with 2 WIC and 1WIC ISDN s/t
I ´ve a Cisco 2801 with IOS IPBASE
and 2 WIC modules DSL over POTS
and 1 WIC module ISDN s/t V3
My problem is, when i call to the ISDN interface , It report me a error that it.
*Jan 2 11:51:45.355: %SYS-3-INVMEMINT: Invalid memory action (free) at
interrupt level -Traceback= 0x608CAA20 0x60202594 0x6021B078 0x6021161C
*Jan 2 11:51:45.359: ASSERTION FAILED: file "../chips/gt96k/gt96k_timer.c", lin
e 771"
I debug all ISDN debugs
When i am configuring the ISDN interface
and select the ISDN switch-type then crash with this error log
"*Jan 12 15:36:48.851: ISDN Error: Invalid DSL (0) Q921d: L2_AddTeiCes: dsl_id= 0, tei=127, ces=0, chan=0"
im lost. thanks
1 REPLY
Re: Problem Cisco 2801 with 2 WIC and 1WIC ISDN s/t
Below mentioned is the H/W matrix supported by 2801.
4 slots; 2 slots support HWIC, WIC, VIC, or VWIC type modules
1 slot supports WIC, VIC, or VWIC type modules
1 slot supports VIC or VWIC type modules
I have seen a workaround to swap the card to another slot and check for the status on the alternat slot.
May be the possibile reason here would be u mite be trying to instal in VIC/WVIC oriented slots..
Also the exact IOS code being run in this box can be a possible reason.is it possible to change the feature set from simple ip base to ip plus feature set of whtever version ur having at present..
regds
170
