Problem configuring QoS in Cisco861
I'm having problems to configure QoS in Cisco861 with IOS 15.0M. What I want is quite simple, I want to configure two VLAN with different traffic shaping/policing policitics towards Internet:
VLAN 1 - 2/1 Mbps
VLAN 2 - 8/1 Mbps
WAN Interface is 10/2 Mbps
FIRST. I tried to configure traffic policing/shaping in the WAN Interface (Fa4). But it worked only for the outbound traffic and not for the inbound traffic, I suspect that is due to source NAT (Am I wrong?). The download test give me 3Mbps (class-default), bad behaivour, and the upload test is done well 1Mbps.
ip access-list extended wired-users
permit ip 192.168.1.0 0.0.0.255 any
permit ip any 192.168.1.0 0.0.0.255
class-map match-any wired-users
match access-group name wired-users
policy-map wan-output
class wired-users
   police cir 1000000
     conform-action transmit
     exceed-action drop
     violate-action drop
class class-default
   police cir 3000000
     exceed-action drop
     violate-action drop
interface FastEthernet4
description Internet
ip address 172.16.4.22 255.255.255.0
ip nat outside
ip virtual-reassembly
zone-member security internet
duplex auto
speed auto
service-policy input wan-output
service-policy output wan-output
end
SECOND, due to the limitation discovered I configure police/shape in the switch port fa0. I remark that this is a switchport and not a routeport. I disable the service-policy of the wan interface and enable the service policy only in the fa0 interface. The results are even worse. None direction is limited, download test gave me 25Mbps and the upload test 5,5 Mbps.
class wired-users
   police cir 1000000
     exceed-action drop
     violate-action drop
class class-default
   police cir 3000000
     exceed-action drop
     violate-action drop
interface FastEthernet0
description Puerto Usuarios Cableada
end
interface Vlan1
description Red Usuarios Cableada
ip nat inside
zone-member security wired
end
THIRD, I also tried to configure the service policy in the SVI interface (vlan1) but it means that it not possible to configure a service-policy in a SVI interface.
Could you give me some advice about how to configure shaping/policing to get what I want? It's the first time I try to configure QoS in Cisco as it's obvious
Thanks!
Christian
172
