Problem in phyiscal ATM interface for ASR 1006
Good day
I have two ASR routers 1006 with IOS Version   asr1000rp1-adventerprisek9.03.01.00.S.150-1.S.bin as mentiond in the attached files
ASR-A and ASR-B My problem i need to bring the link up  between two routers connected with fiber link through  DWDM in the  physical interfaces not in the subinterfaces  as mentiond below and attached in the files
  Find below  router specs when i removed the configurtion from the subinterface and pasted in the physical interface
iam not able the ping the ip address and the ospf neighber ship and mpls went down its only work in the subinterface
so please i need any help for that issue
Find below the configuration
interface ATM1/1/0
description *** Connected To ASR-A-PE_A2/0 ****
no ip address
atm clock INTERNAL
atm framing sdh
no atm ilmi-keepalive
no atm enable-ilmi-trap
interface ATM1/1/0.100 point-to-point
ip address 10.102.250.53 255.255.255.252
ip ospf 102 area 0
mpls ip
pvc 1/100
  protocol ip 10.102.250.54 broadcast
ASR-B-PE#show platform
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP10       ok                    8w4d
0/0      SPA-10X1GE-V2       ok                    8w4d
1         ASR1000-SIP10       ok                    8w4d
1/0      SPA-10X1GE-V2       ok                    8w4d
1/1      SPA-1XOC3-ATM-V2    ok                    8w4d
R0        ASR1000-RP1         ok, active            8w4d
F0        ASR1000-ESP10       ok, active            8w4d
P0        ASR1006-PWR-AC      ok                    8w4d
P1        ASR1006-PWR-AC      ok                    8w4d
Slot      CPLD Version        Firmware Version
0         09111601            12.2(33r)XNC
1         09111601            12.2(33r)XNC
R0        07062111            12.2(33r)XNC
F0        07091401            12.2(33r)XNC
  • WAN Routing and Switching
289
