Problem installing a HWIC-1FE in a 1841 series Router
vulatec89
Hi, I have a problem installing a HWIC-1FE in a 1841 series Router, I already install the interface in the router slot 1 because in the slot 0 I have installed a VWIC 2-2MFT G703 card.
The problem is: when I write the command show ip interface brief, the new fastethernet interface does not appear.
The IOS I have is:
c1841-ipbase-mz.124-1c.bin,
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SO FTWARE (fc1)
¿I need to write any command to activate the interface?
¿I need a different IOS version?
Thanks for any help you can give me.
Nagaraja Thanthry
You need a minimum of 12.4(15)T image for the card to be supported on the
router. So, please upgrade the router to 12.4(15)T or higher (in the T
train).
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet
0900aecd80581fe6_ps5855_Products_Data_Sheet.html
Hope this helps.
NT
Dear NT,
Thanks for your answer, so I am going to try upgrading my IOS
Best Regards.
