Community Member
Problem line protocol with 28xx NM-16ESW
I have a problem with a 2851 router connected to Microwave device. Line protocol goes up and down continuously on all interfaces. Microwave has 4 Ethernet connections plugged on a NM-16ESW of the router such as:
Fa1/1 on NM-16ESW <-> Ethernet1 of microwave
Fa1/2 on NM-16ESW <-> Ethernet2 of microwave
Fa1/3 on NM-16ESW <-> Ethernet3 of microwave
Fa1/4 on NM-16ESW <-> Ethernet4 of microwave
We have made Factory Acceptance Test before deployment where all was working well.
We tried all combination of speed (100M or Auto) and Duplex (Full or Auto) but problem still occurred.
We found a workaround (but non sustainable) by inserting a switch (3560) between Microwave and router: One link between router and switch, and the 4 Ethernet connection of Microwave on the switch.
The same problem occurred on a 2821.
Thank you for your assistance!
Best regards
Florian
1 ACCEPTED SOLUTION
Community Member
Re: Problem line protocol with 28xx NM-16ESW
do you have PoE on these module ?
try to desactivate the poe with power inline never command
Olivier
Hall of Fame Super Gold
Try disabling keepalives under vlan 100.
Community Member
Please find below the configuration of Vlan100 :
interface Vlan100
ip address 10.52.38.252 255.255.255.192
standby 100 ip 10.52.38.254
standby 100 priority 110
standby 100 preempt
You would then add "no keeepalives" under it.
Community Member
I could not add the command "no keepalive" under interface vlan 100. So I type the command for the 4 interfaces :
interface FastEthernet1/1
description *** Sectorielle 1 ***
switchport access vlan 100
duplex full
speed 100
no keepalive
spanning-tree portfast
interface FastEthernet1/2
description *** Sectorielle 2 ***
duplex full
speed 100
no keepalive
interface FastEthernet1/3
description *** Sectorielle 3 ***
duplex full
speed 100
no keepalive
interface FastEthernet1/4
description *** Sectorielle 4 ***
duplex full
speed 100
no keepalive
We made another test by plugin only port Fa1/3 but the problem is still there :
Ro-vlau-gir-1#ter mon
*Feb 3 13:25:59.852: %LINK-3-UPDOWN: Interface FastEthernet1/3, changed state to up
*Feb 3 13:26:00.852: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to up
Ro-vlau-gir-1#
*Feb 3 13:26:12.064: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to down
Ro-vlau-gir-1#
*Feb 3 13:26:13.068: %LINK-3-UPDOWN: Interface FastEthernet1/3, changed state to up
*Feb 3 13:26:14.068: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to up
Ro-vlau-gir-1#
*Feb 3 13:26:18.636: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to down
*Feb 3 13:26:19.648: %LINK-3-UPDOWN: Interface FastEthernet1/3, changed state to up
Ro-vlau-gir-1#
*Feb 3 13:26:20.648: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to up
Ro-vlau-gir-1#
*Feb 3 13:26:23.336: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to down
Ro-vlau-gir-1#
*Feb 3 13:26:24.340: %LINK-3-UPDOWN: Interface FastEthernet1/3, changed state to up
*Feb 3 13:26:25.340: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to up
Ro-vlau-gir-1#
*Feb 3 13:26:29.820: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to down
Ro-vlau-gir-1#
*Feb 3 13:26:30.840: %LINK-3-UPDOWN: Interface FastEthernet1/3, changed state to up
*Feb 3 13:26:31.840: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to up
Ro-vlau-gir-1#
*Feb 3 13:26:34.608: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to down
Ro-vlau-gir-1#
*Feb 3 13:26:35.616: %LINK-3-UPDOWN: Interface FastEthernet1/3, changed state to up
*Feb 3 13:26:36.616: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to up
Ro-vlau-gir-1#
*Feb 3 13:26:40.908: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to down
Ro-vlau-gir-1#
Ro-vlau-gir-1#
*Feb 3 13:26:41.916: %LINK-3-UPDOWN: Interface FastEthernet1/3, changed state to up
*Feb 3 13:26:42.916: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to up
Ro-vlau-gir-1#
*Feb 3 13:26:45.884: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/3, changed state to down
And so on.
Sorry, I wouldn't know what to suggest. Seems a sort of incompatibility, but not sure of which kind exactly.
Community Member
try to implement :
switchport mode access
Community Member
Olivier
Community Member
I don't think PoE is available in the NM-16ESW. For PoE that's NM-16ESW-PWR card.
Here is the output of "show inventory" command :
NAME: "16 Port 10BaseT/100BaseTX EtherSwitch", DESCR: "16 Port 10BaseT/100BaseTX EtherSwitch"
PID: NM-16ESW , VID: V01 , SN: FOC122349FD
But I will try the "power inline never" command.
Community Member
Ok, but I see that (check the last ref) :
Ro-vlau-gir-1#sh inv
NAME: "2851 chassis", DESCR: "2851 chassis"
PID: CISCO2851 , VID: V04 , SN: FHK1225F5DU
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1", DESCR: "VWIC2-2
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC1223617Y
NAME: "PVDMII DSP SIMM with four DSPs", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC12244ZCP
PID: PVDM2-64 , VID: V01 , SN: FOC1224505N
EtherSwitch"
NAME: "Power daughter card for 16 port EtherSwitch NM", DESCR: "Power daughter c
PID: PPWR-DCARD-16ESW , VID: V01 , SN: FOC121924RQ
Ro-vlau-gir-1#
Where do you see that? OP never posted complete output of "show inventory".
Also, PoE requires the PoE PS, that is only seen with "show environment".
Community Member
please find below the "show environment" result :
Ro-vlau-gir-1#sh environment
Main Power Supply is AC with -48V
-48V supply status: OK
-48V relay status: NON-ISOLATED
Fan 1 OK
Fan 2 OK
Fan 3 OK
System Temperature: 25 Celsius (normal)
Environmental information last updated 00:00:02 ago
So you have a full PoE router and the "power inline newer" recommendation does make sense.
395
