Webcast-Catalyst9k
Problem transferring IOS onto a Cisco 3550 48 SMI
Someone cleared the Flash from a Cisco 3550 48 SMI at my work (It probably needed updating anyway) and I'm trying to simply transfer the newest IOS onto the switch.  I keep getting errors and everything i've found online has been no help.  When transferring using Xmodem, the window counts up to 9 retries with the "Last error" field showing "Got Retry Request".  Then i recieve a box telling me "File transfer error limit exceeded.  These errors are preventing successful transfer file.  Please see Troubleshooting in online documentation."  I originally tried to connect at 115200 8-N-1 in order to speed up the transfer but i also tried 9600 after the first time i recieved the error.  Also, i've tried using both Xmodem and Xmodem-1k.  Here is a copy/paste of what i've done.
switch: format flash:
Are you sure you want to format "flash:" (all data will be lost) (y/n)?y
flashfs[0]: 0 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 15997952
flashfs[0]: flashfs fsck took 14 seconds.
Filesystem "flash:" formatted
switch: flash_init
Initializing Flash...
...The flash is already initialized.
switch: load_helper
switch: copy xmodem: flash:c3550-ipbase-mz.122.44.SE6.bin
Begin the Xmodem or Xmodem-1K transfer now...
CCCCCxmodem:: I/O error
switch: BB0
Unknown cmd: BB0
switch:
Hall of Fame Super Gold
Describe your TFTP client.  It looks like Xmodem is waiting for you to initiate the transfer and runs out of time.  Are you using a USB-to-Serial cable?
Have you tried a different machine?
I'm using Hyperterminal, and i do initate the the transfer in the Hyperterminal menu.  And i'm using a DB-9 to RJ-45 connector.  I haven't had the opportunity to use another computer to attempt the transfer.
Wrong forum, post in "LAn and switching". You can move your posting with the Actions panel on the right.
341
