Webcast-Catalyst9k
Problem when start the router
When i power up the router, it shows me the message below. May I know why?
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Copyright (c) 2003 by cisco Systems, Inc.
C2600 platform with 131072 Kbytes of main memory
rommon 1 >
Re: Problem when start the router
is the IOS present in flash. check with command:
>dir flash:
if its present then issue this command:
>boot flash: filename
This should work if the iOs is there in flash.
That means the ios or flash problem. Mostly the IOS.
Try to give the dir flash command and find if there is any ios available in the flash.
Then boot it from rommon mode.
If this does not work then upgrade a new ios.
Let us know if any help required.
Silver
try to copy the IOS with tftpdnld from rommon (you'll erase the flash after). Then try to download a news IOS image, and upload again on your router.
Andrea
Can give me the link to download the latest IOS image for cisco 2600?
You have to specify which kind of software you are intrested in: Ip-base, enterprise etc.
Use the Software planner to select you best choice.
Silver
an alternative: Cisco Feature Navigator
http://www.cisco.com/go/fn
to download an IOS release software is required a contract open.
Andrea
we do not have the maintenance contract, is there any alternative way to download?
Silver
Nope, sorry.
Andrea
134
