Problem with 2951 and DS3
rwharris13
I had a 7206 router that I was trying to replace with a 2951 with an NM-1T3/E3 module. When I move the DS3 to the 2951 the DS3 will not come up. To my knowledge there's nothing essentially different from how these two are configured so I'm not sure what I've missed.
My config from the 7206 was simple:
interface Serial1/0
ip address X.X.X.X X.X.X.X
encapsulation ppp
dsu bandwidth 44210
framing c-bit
cablelength 10
serial restart-delay 0
end
Some output of show controller from 7206:
M2T-T3+ pa: show controller:
PAS unit 0, subunit 0, f/w version 3-93, rev ID 0x2800001, version 3
idb = 0x64FB4AB0, ds = 0x64FB5C70, ssb=0x64FB6034
Clock mux=0x30, ucmd_ctrl=0x0, port_status=0x1
Serial config=0x8, line config=0x1B0202
maxdgram=4584, bufpool=128Kb, 256 particles
   rxLOS inactive, rxLOF inactive, rxAIS inactive
   txAIS inactive, rxRAI inactive, txRAI inactive
line state: up
cable type : T3  cable, received clockrate 44202795
base0 registers=0x3C800000, base1 registers=0x3C802000
mxt_ds=0x673180B4, rx ring entries=124, tx ring entries=254
statring=0xE354600, statr shadow=0x64FB9464, stat_head=314
rxring=0xE3543C0, rxr shadow=0x64FB8E30, rx_head=94
txring=0xE354C40, txr shadow=0x64FBA098, tx_head=239, tx_tail=243, tx_count=4
throttled=0, enabled=0
halted=0, last halt reason=0
Microcode fatal errors=0
rx_no_eop_err=0, rx_no_stp_err=0, rx_no_eop_stp_err=0
rx_no_buf=0, rx_soft_overrun_err=0, dump_err= 0, bogus=0, mxt_flags=0x2C
tx_underrun_err=0, tx_soft_underrun_err=0, tx_limited=0(256)
tx_fullring=18228, tx_started=2294571312, mxt_flush_count=0
rx_int_count=38895217, tx_int_count=-657719664
   Framing is c-bit, Clock Source is Line
   Bandwidth limit is 44210, DSU mode 0, Cable length is 10 feet
   rx FEBE since last clear counter 0, since reset 578761
   Data in current interval (623 seconds elapsed):
Output from show interface s1/0 on 7206 when it was working:
Serial1/0 is up, line protocol is up
  Hardware is M2T-T3+ pa
  Description: (Circuit ID)
  Internet address is X.X.X.X
  MTU 4470 bytes, BW 44210 Kbit/sec, DLY 200 usec,
     reliability 255/255, txload 11/255, rxload 11/255
  Encapsulation PPP, LCP Open
  Stopped: CDPCP
  Open: IPCP, TAGCP, crc 16, loopback not set
  Keepalive set (10 sec)
  Restart-Delay is 0 secs
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 8w1d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 25407
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1973000 bits/sec, 407 packets/sec
  5 minute output rate 2054000 bits/sec, 667 packets/sec
     1993876858 packets input, 772670269 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
              0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     3076174408 packets output, 5251513 bytes, 0 underruns
     0 output errors, 0 applique, 0 interface resets
     0 unknown protocol drops
     0 carrier transitions
Here's the running config section for the DS3 on the 2951:
card type t3 1
controller T3 1/0
clock source line
cablelength 10
interface Serial1/0
encapsulation ppp
dsu bandwidth 44210
Some info from 2951 show controller output :
T3 1/0 is down.
  Applique type is Subrate T3
  Transmitter is sending remote alarm.
  Receiver has no alarms.
  MDL transmission is disabled
  FEAC code received: No code is being received
  Framing is C-BIT Parity, Line Code is B3ZS, Clock Source is Line
  Data in current interval (670 seconds elapsed):
And from 2951 serial interface:
Serial1/0 is down, line protocol is down
  Hardware is DSXPNM Serial
  Internet address is X.X.X.X/30
     reliability 254/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP Closed, crc 16, loopback not set
  Last input 12w1d, output 12w1d, output hang never
  Last clearing of "show interface" counters 01:48:36
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
DSU mode 0, bandwidth 44210, real bandwidth 44210, scramble 0
Edison Ortiz
Framing looks the same but I don't see the line code from the 7200 router.
Are you sure it was B3ZS?
Check with your provider.
Ended up being a bad NM-1T3/E3 card, couldnt see a hard loop and we swapped it then everything worked!
Thanks for posting back to the forum to let us know that you have resolved the issue and that the problem turned out to be on the card. This might help other readers of the forum who might face similar problems.
Rick
Rick
