problem with aim-voice-30 and vwci-2mft.g703
erodrig
hi
i have a cisco 2620xm with an aim-voice-30 and a vwic-2mft-g703 and i want to use one port of the vwic to connect with the pbx (ds0-group 0) and the other port to a mpls link (channel-group 0)but when i try to configure the channel-group i get this:
MPLS_ROUTER(config-controller)#channel-group 0 timeslots 1-31
%The MFT-VWIC module is already connected to AIM slot,
cannot create Channel groups using onboard SCC.
Please reconfigure channel-group command with"aim #aim-slot" keyword
%Insufficient resources to create channel group
do i need to configure something else?
the ios version is c2600-js-mz.123-6b.bin
thanks
paolo bevilacqua
You cannot use the second port of the VWIC for data when the first is used for voice in a 2600.
You will need to get a separate VWIC for the purpose. It doesn't need to be of the g703 variety that is more expensive.
Hope this help, please rate post if it does!
purohit_810
Level 5
Level 5
It will support only one channel group. If you are going to create another channel group than you will get that error:
Note When NMSI mode is configured, the controller will support only one channel-group. If you try to configure more than one channel-group, the following error message will occur:
router(config-controller)#channel-group
2 timeslots 3
%Channel-group already created.
%Only 1 channel-group can be configured
with independent clocking.
channel group
When configuring between clock source independent and no clock source independent, the channel-group has to be removed.
See on URL: http://www.cisco.com/en/US/products/hw/routers/ps221/prod_configuration_guide09186a00800a4063.html
Step:4 in E1 Unstructured configuration.
Dharmesh Purohit
That is incorrect. The question is about configuring a single channel-group on a VWIC that is also used for voice with AIM-VOICE30.
As I mentioned above, this is not supported.
Hi Paolo
is there any document or link of cisco with this information?
