Webcast-Catalyst9k
problem with DLSW+
I have the following topology:
AS400 -- Cisco 2811 -- WAN -- Cisco 1841 -- Control Unit
Configuration of Cisco 2811:
interface Loopback0
ip address 192.168.153.100 255.255.255.255
dlsw local-peer peer-id 192.168.153.100 promiscuous
interface Serial0/2/0
description AS400
no ip address
encapsulation sdlc
no keepalive
nrzi-encoding
clockrate 19200
sdlc role secondary
sdlc vmac 4053.9010.0100
sdlc address 01
sdlc xid 01 056E9EF0
sdlc partner 4053.9011.2100 01
sdlc dlsw 1
Configuration of Cisco 1841:
interface Loopback0
ip address 192.168.153.112 255.255.255.255
dlsw local-peer peer-id 192.168.153.112
dlsw remote-peer 0 tcp 192.168.153.100
interface Serial0/1/0
description Control Unit
no ip address
encapsulation sdlc
no keepalive
nrzi-encoding
clockrate 9600
sdlc role primary
sdlc vmac 4053.9011.2100
sdlc poll-pause-timer 100
sdlc address 01
sdlc xid 01 05F00001
sdlc partner 4053.9010.0100 01
sdlc dlsw 1
On Cisco 1841:
BCS-SILC_CASALETTO#sh int s0/1/0
Serial0/1/0 is up, line protocol is up
Hardware is GT96K Serial
Description: Control Unit
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation SDLC, loopback not set
Router link station role: PRIMARY (DCE)
Router link station metrics:
slow-poll 10 seconds
T1 (reply time out) 3000 milliseconds
N1 (max frame size) 12016 bits
N2 (retry count) 20
poll-pause-timer 100 milliseconds
poll-limit-value 1
k (windowsize) 7
modulo 8
sdlc vmac: 4053.9011.21--
sdlc addr 01 state is USBUSY
cls_state is CLS_STN_CLOSED
VS 0, VR 0, Remote VR 0, Current retransmit count 0
Hold queue: 0/200 IFRAMEs 0/0
TESTs 10/10 XIDs 0/0, DMs 0/0 FRMRs 0/0
RNRs 1404306/0 SNRMs 1/0 DISC/RDs 0/0 REJs 0/0
Poll: clear, Poll count: 0, ready for poll, chain: 01/01
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d19h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 9 packets/sec
5 minute output rate 0 bits/sec, 9 packets/sec
1404317 packets input, 2808894 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1404317 packets output, 2808894 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
With this configuration AS400 is not able to open dlsw circuit with Control Unit.
Could someone help me?
Stefano
Re: problem with DLSW+
Hello Stefano,
double-check the MAC addresses configured. Also, I am not sure if the difference in clock rates might be a problem, you might want to try and set both sides to the same value...
Have a look at this document as well:
Troubleshooting DLSw: SDLC
http://www.cisco.com/en/US/tech/tk331/tk336/technologies_tech_note09186a0080094cef.shtml#t1
Let me know if you need more help...
GNT
I modified clockrate on Cisco 1841 serial interface in order to have the same value on both sides, but it is still not working.
The MAC addresses configured are virtual MAC addresses I randomly picked.
Thanks a lot for the troubleshooting doc.
I activate debug sdlc packets/events on both sides.
At AS400 side I have no message, at Control Unit side I have the following log messages on Cisco 1841:
May 2 10:48:09.588: SDLC: Sending RR/RNR at location 4, Serial0/1/0 1
May 2 10:48:09.588: Serial0/1/0: SDLC O 01 USBUSY (2) RNR P/F 0 s: 0 r: 0 rr: 0
May 2 10:48:09.588: Serial0/1/0 SDLC output 0115
May 2 10:48:10.504: Serial0/1/0: SDLC I 01 USBUSY (2) RR P/F 0, [VR: 0 VS: 0]
May 2 10:48:10.504: Serial0/1/0 SDLC input 0111
May 2 10:48:10.928: Serial0/1/0: SDLC T 01 USBUSY 0x13578B9C P 0
May 2 10:48:10.928: SDLC: Sending RR/RNR at location 4, Serial0/1/0 1
May 2 10:48:10.928: Serial0/1/0: SDLC O 01 USBUSY (2) RNR P/F 0 s: 0 r: 0 rr: 0
May 2 10:48:10.928: Serial0/1/0 SDLC output 0115
May 2 10:48:10.936: Serial0/1/0: SDLC I 01 USBUSY (2) RR P/F 0, [VR: 0 VS: 0]
May 2 10:48:10.936: Serial0/1/0 SDLC input 0111
May 2 10:48:11.036: Serial0/1/0: SDLC T 01 USBUSY 0x13578D4C P 0
May 2 10:48:11.036: SDLC: Sending RR/RNR at location 4, Serial0/1/0 1
May 2 10:48:11.036: Serial0/1/0: SDLC O 01 USBUSY (2) RNR P/F 0 s: 0 r: 0 rr: 0
May 2 10:48:11.036: Serial0/1/0 SDLC output 0115
May 2 10:48:11.040: Serial0/1/0: SDLC I 01 USBUSY (2) RR P/F 0, [VR: 0 VS: 0]
May 2 10:48:11.040: Serial0/1/0 SDLC input 0111
Best regards
Stefano
Silver
I hope routing is all set and you are able to ping the two loopback addresses.
What does show dlsw look like on both sides?
Thanks.
Hall of Fame Super Gold
Stefano
I am a little confused. The control unit connection is serial/SDLC and the AS400 connection is serial/SDLC. This leads me to believe that the definition in the AS400 for the remote device is an SDLC definition. So why are the router configurations specifying MAC addresses? The router configs look like they are trying to translate an SDLC connection to a LAN connection but it seems that both ends are expecting SDLC.
In a traditional SNA SDLC connection both ends of the connection would have the same clock rate. One of the advantages of DLSW is that it can buffer and compensate for clocking differences between the two ends. I doubt that the different clock rates are the problem.
The suggestion about checking routing is good and about pinging is good. In particular you should do an extended ping (on both ends to be thorough) which specifies the remote loopback address as the destination and specifies the local loopback as the source. And the output of show DLSW could be helpful.
Rick
Hi Rick,
routing is working well and I can ping from Cisco 1841 loopback address to Cisco 2811 loopback address and viceversa.
Moreover, from 'sh dlsw peer' on both sides I can see that dlsw peers are connect:
BCS-SILC_TRESCORE1#sh dlsw pee
Peers: state pkts_rx pkts_tx type drops ckts TCP uptime
TCP 192.168.153.112 CONNECT 12956 603419 prom 0 0 0 3d18h
Total number of connected peers: 1
Total number of connections: 1
BCS-SILC_CASALETTO#sh dlsw pee
TCP 192.168.153.100 CONNECT 603310 12958 conf 0 0 0 3d18h
Look at serial interface configuration on Cisco 2811:
description AS400
no ip address
encapsulation sdlc
no keepalive
nrzi-encoding
clockrate 19200
sdlc role secondary
sdlc address 01
sdlc dlsw 1
As you can see remote device is configured as sdlc remote device with commands 'sdlc address 01' and 'sdlc xid 01 056E9EF0'. The MAC addresses configured are virtual MAC addresses I randomly picked and they are used in sdlc partner definition.
I can't understand when you say that the router configs look like they are trying to translate an SDLC connection to a LAN connection...
Best regards
Stefano
Anyway the Serial interface on Cisco 2811 is still down/down (even if clockrate and duplex mode match values configured o AS400) and the sdlc status is still CLS_STN_CLOSED. The Serial interface on Cisco 1841 is up/up, Control Unit replies to sdlc test packets but the state is still CLS_STN_CLOSED
Best regards
Stefano
381
