Problem with extending VRF instance over WAN
shanemoss
Hi Folks,
I have a network where we use several VRF instances to segregate the network, routing between VRFs is via a firewall. We use BGP to exchange routes between the VRFs and MPLS to provide next hop connectivty, EIGRP is used as the enterprise routing protocol.  This works just fine in the LAN environment.  I now wish to extend a particular VRF to a remote router across a WAN connection so that I can firewall a particular subnet attached to the remote router.  I have configured the VRFs, BGP and MPLS but cannot ping between the networks - any help would be appreciated.
Thanks.
! The following is the relevent config on the remote router
ip vrf WRN
rd 65000:6760
route-target export 65000:760
route-target import 65000:760
mpls label protocol ldp
interface Loopback4
ip address 172.16.90.4 255.255.255.255
interface GigabitEthernet0/0
description #### WAN Link  ####
ip address 172.17.91.2 255.255.255.252
mpls ip
interface GigabitEthernet0/1.93
encapsulation dot1Q 93
ip vrf forwarding WRN
ip address 172.16.93.1 255.255.255.0
router bgp 65000
no bgp default ipv4-unicast
no bgp default route-target filter
bgp log-neighbor-changes
neighbor 10.3.0.1 remote-as 65000
neighbor 10.3.0.1 update-source Loopback4
address-family ipv4
  redistribute connected
  no auto-summary
  no synchronization
exit-address-family
address-family vpnv4
  neighbor 10.3.0.1 activate
  neighbor 10.3.0.1 send-community extended
exit-address-family
address-family ipv4 vrf WRN
  neighbor 10.3.0.1 next-hop-self
  no synchronization
exit-address-family
mpls ldp router-id Loopback4 force
Local Router
ip vrf WRN
rd 65000:3760
tag-switching tdp router-id Loopback0 force
interface Loopback0
ip address 10.3.0.1 255.255.255.255
! This is active on a physical inetrface
interface Vlan760
description ###   FW_WRN   ###
ip address 10.200.2.19 255.255.255.240
router bgp 65000
neighbor XYZ peer-group
neighbor XYZ remote-as 65000
neighbor XYZ update-source Loopback0
neighbor XYZ timers 20 60
neighbor 172.16.90.4 peer-group XYZ
address-family ipv4
redistribute static
default-information originate
no auto-summary
no synchronization
exit-address-family
neighbor XYZ activate
neighbor XYZ route-reflector-client
neighbor XYZ next-hop-self
neighbor XYZ send-community extended
bgp scan-time import 5
bgp scan-time 20
exit-address-family
redistribute static
no auto-summary
no synchronization
exit-address-family
ip route vrf WRN 0.0.0.0 0.0.0.0 10.200.2.30
On the remote router I can see the default route that has been propogated from the local router
C       172.16.93.0 is directly connected, GigabitEthernet0/1.93
     10.0.0.0/28 is subnetted, 1 subnets
B       10.200.2.16 [200/0] via 10.3.0.1, 00:50:55
B*   0.0.0.0/0 [200/0] via 10.3.0.1, 00:50:55
But I cannot ping any devices in the 10.200.2.16 subnet, the following is also an issue for me; why is it active rather than established? And if it isn't established, why am I seeing routes advertised by this 10.3.0.1 router?
Router# sho ip bgp vpnv4 vrf WRN summary
BGP router identifier 172.16.90.4, local AS number 65000
BGP table version is 102, main routing table version 102
3 network entries using 411 bytes of memory
5 path entries using 340 bytes of memory
25/23 BGP path/bestpath attribute entries using 3100 bytes of memory
4 BGP rrinfo entries using 96 bytes of memory
13 BGP extended community entries using 312 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 4259 total bytes of memory
BGP activity 103/0 prefixes, 105/0 paths, scan interval 15 secs
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.3.0.1        4 65000       0       0        0    0    0 never    Active
13 Replies 13
I think that the routes that you are seing are on the main routing table, not on the WRN table. You have one more adj. on ipv4 address family. Check :
show ip bgp all summary
First of all the adj on the address family vrf WRN is made with source/dst Loop 0 and Loop 4 , that is not on the vrf WRN.
Is there a layer 2 connection between the two routers , or how is the transport of the VRF WRN made over the WAN ?
Dan
Hi Dan,
You are correct, the routes are on the main routing table.  I've removed the neighbor from the main bgp config so now it looks like the following.  There is no layer 2 connection between these two routers. My understanding was that MPLS can be used instead of requiring direct L2 access between peers?  My problem may be that MPLS is not set up correctly?
Shane.
router bgp 65000
address-family ipv4
  no auto-summary
  no synchronization
exit-address-family
exit-address-family
  no synchronization
exit-address-family
! I've since added 10.5.0.1 as an neighbor so you'll see this listed in the output below.
Router#show ip bgp all summary
For address family: VPNv4 Unicast
BGP table version is 201, main routing table version 201
1 network entries using 137 bytes of memory
1 path entries using 68 bytes of memory
3/1 BGP path/bestpath attribute entries using 372 bytes of memory
1 BGP extended community entries using 24 bytes of memory
BGP using 601 total bytes of memory
BGP activity 103/97 prefixes, 105/99 paths, scan interval 15 secs
10.5.0.1        4 65000       0       0        0    0    0 never    Active
Router#
In order to use MPLS you will need layer2 conectivity between those 2 routers or an mpls cloud which will exchange mpls labels in order to have end-to-end LSP created between the routers.
Is there any consideration for the mpls configuration ? From my understading you need to divide some traffic between 2 locations , is my understanding correct ? You can use only VRF-lite ( the same technology with out mpls label exchange ).
Can you explane mode your topology , and what are you tring to achive ?
Dan
I have enabled MPLS LDP end to end.  It is possible that there is something wrong in my MPLS configuration.  The VRF routing table looks correct on both sides;
Router#sho ip route vrf WRN
Routing Table: WRN
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.3.0.1 to network 0.0.0.0
     172.16.0.0/24 is subnetted, 1 subnets
B       10.200.2.16 [200/0] via 10.3.0.1, 02:28:20
B*   0.0.0.0/0 [200/0] via 10.3.0.1, 02:28:20
But I still cannot ping.  The MPLS forwarding looks correct, the command;
Router#sho ip bgp vpnv4 vrf WRN labels
   Network          Next Hop      In label/Out label
Route Distinguisher: 65000:6760 (WRN)
   0.0.0.0          10.5.0.1        nolabel/223
                    10.3.0.1        nolabel/203
   10.200.2.16/28   10.5.0.1        nolabel/221
                    10.3.0.1        nolabel/202
   172.16.93.0/24   0.0.0.0         16/aggregate(WRN)
shows label 202 or 221 to reach network 10.200.2.16/28, these appear to be correct end to end - has anyone any suggestions why I cannot pass traffic across the network between these two VRF interfaces?
Thanks in advance.
What about your Vlans?
What do you mean about the VLANs?
Shane I'm whipping up a basic config in GNS.. I will paste it shortly.
MPLS it's not black magic, the packets need to be trasfered over a layer 2 and layer 1 transport . The thing with the mpls is that there is no IP DST check as in normal IP routing. There are some label distribution protocols ( LDP or TDP ) that are generating those labels based on the routing table. In order to exchange labels you need to have LDP or TDP adjancency between the routers that are running MPLS.  I do belive that your locations are connected via a provider that maybe is providing you this connection via MPLS. Can you confirm ?
You can check "your" LDP adj with :  sh mpls ldp neighbor
Dan
Thanks Dan,
I do have end to end layer 2 connectivity.  Our core network uses MPLS, our WAN link to the remote site is a point to point link with an ethernet presentation - no MPLS from the provider.
Router#sho mpls ldp neighbor
    Peer LDP Ident: 172.16.90.5:0; Local LDP Ident 172.16.90.4:0
        TCP connection: 172.16.90.5.58102 - 172.16.90.4.646
        State: Oper; Msgs sent/rcvd: 1380/1687; Downstream
        Up time: 20:01:16
        LDP discovery sources:
          GigabitEthernet0/0, Src IP addr: 172.17.91.1
        Addresses bound to peer LDP Ident:
          172.17.91.6     172.16.90.1     172.16.90.3     172.16.90.5
          172.17.91.1
Router#
172.17.91.1 is the router on the local side of the WAN link.  My understanding is that vrf labels are not assigned by LDP but rather by BGP so;
Router#show ip bgp vpnv4 vrf WRN labels
Router#
I'm at a loss to explain why I cannot ping 10.200.2.16/28 addresses.
Thanks again,
Shane.
Can you paste from both ends :
show mpls interface
show mpls neigh
show mpls for
Dan
wilson-danny
Hey Shane,
I didn't get too much time to spend on it, but it works..
VLAN ISL Id: 100
    Media Type: Ethernet
    VLAN 802.10 Id: 100100
    State: Operational
    MTU: 1500
ip cef
no ip domain lookup
ip vrf test
rd 500:500
route-target export 500:500
route-target import 500:500
interface Loopback172
ip vrf forwarding test
ip address 172.16.0.2 255.255.255.255
interface FastEthernet0/0
ip address 10.0.0.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.1.2 255.255.255.0
ip router isis
mpls ip
router isis
net 59.0001.0000.0000.0004.00
is-type level-1
router bgp 500
no synchronization
bgp router-id 172.16.0.2
no auto-summary
address-family ipv4 vrf test
  redistribute static
  redistribute eigrp
  neighbor 192.168.1.1 remote-as 500
  neighbor 192.168.1.1 ebgp-multihop 255
  neighbor 192.168.1.1 update-source FastEthernet0/0.100
  neighbor 192.168.1.1 activate
  neighbor 192.168.1.1 send-community both
  neighbor 192.168.1.1 soft-reconfiguration inbound
  no synchronization
exit-address-family
no ip http server
no ip http secure-server
ip route vrf test 172.16.0.1 255.255.255.255 192.168.1.1
Hi folks,
I now believe that the problem is related specifically to MPLS and either the way it is configured or some issue with the WAN link.  My setup is as follows;
Core Network -> Local WAN Router -> Remote Site Router
Issueing the command "show mpls forwarding-table" on any core router or the Local WAN router shows a lot of tags but the same command on the remote router shows only the directly attached network (The one configured as a vrf interface)
Router#sho mpls forwarding-table
Local  Outgoing    Prefix            Bytes tag  Outgoing   Next Hop
tag    tag or VC   or Tunnel Id      switched   interface
17     Aggregate   172.16.93.0/24[V] 520
Router#
I would imagine that the bgp peer 10.3.0.1 should be listed here also but its not.  I've tested my configuration by putting a loopback interface on the local wan router into the WRN vrf and have peered with the 10.3.0.1 neighbor and it all works fine, so it looks like there may be something wrong with MPLS not working across my WAN link. Any ideas what I could be missing?  Thanks in advance.
Figured it out, the issue was due to the next hop not being in the MPLS forwarding-table of the remote router.  This was because of a default summary route being advertised by EIGRP from the local router.  Removal of the summary route meant that the host route to the next hop was then in the global routing table as opposed to a default route allowing a tag to be generated and populated into the MPLS forwarding-table. (A static route to the next hop also worked)
Thanks for your help.
