Webcast-Catalyst9k
problem with mlfr.
do cisco support fragmentation on mlfr? please help me in this regard.
1 REPLY
Bronze
Re: problem with mlfr.
multi link frame relay is supported by cisco.
Specifically my experience is with the 7600 series in which:
.FRF.9 hardware compression is not supported.
•Software compression is not supported.
•Encryption is not supported.
•The maximum differential delay supported is 50 ms when supported in hardware, and 100 ms when supported in software.
•Fragmentation is not supported on the transmit side.
•Frame Relay fragmentation (FRF.12) is not supported.
check out this link (specific to the 7600 series)
http://www.cisco.com/en/US/products/hw/routers/ps368/module_installation_and_configuration_guides_chapter09186a0080440138.html
Hope this helps
106
