Webcast-Catalyst9k
Problem with PRI Drop-and-Insert
We use 2 PABX connected to each other via PRI. Config 2811(please see attached the file) is set between. We have attempted to send PRI via 2811 using Drop-and-Insert. Diagnostic commands do not show any error messages however PABX do not "see" each other.
Could you please give your kind comments how to solve the issue or address me to the right contact.
your prompt response will be highly
Hall of Fame Super Silver
Re: Problem with PRI Drop-and-Insert
Hello Anton,
E1 D channel should be 15 not 16
I think you need to cross-connect timeslot 15 not 16
Hope to help
Giuseppe
Hello Anton,
I've confused the cisco indexes for interfaces that starts with 0.
timeslot 16 should be fine.
there are additional options for the commands like
tdm-group
tdm-group-no
timeslots timeslot-list type [e&m | fxs
[loop-start |
ground-start] fxo [loop-start |
ground-start]
see
http://www.cisco.com/en/US/docs/wireless/mwr_1941/software_configuration/current_scg/DCNcfg.html#wp1109831
but I don't think this applies to you.
Sorry for the confusion
Hope to help
Giuseppe
139
