Problem with QOS policy, No counters!
I have a customer with a QOS issue, there is a policy applied on their multilink for EF, and signalling.  The policy is recording 0 hits.  On the receiving side in our network however I am seeing counters on the various bits.  They have been overrunning the Multilink and have had complaints of voice quality.
CPE
sh policy-map interface
Multilink1
  Service-policy output: CEQoS
    Class-map: Voice (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Strict Priority
        Output Queue: Conversation 264
        Bandwidth 70 (%)
        Bandwidth 3225 (kbps) Burst 80625 (Bytes)
        (pkts matched/bytes matched) 0/0
        (total drops/bytes drops) 0/0
    Class-map: Signal (match-any)
      0 packets, 0 bytes
      Match: ip dscp cs3 (24)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: ip dscp af31 (26)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 265
        Bandwidth 5 (%)
        Bandwidth 230 (kbps)
        (depth/total drops/no-buffer drops) 0/0/0
         exponential weight: 9
         mean queue depth: 0
  class    Transmitted      Random drop      Tail drop    Minimum Maximum  Mark
           pkts/bytes       pkts/bytes       pkts/bytes    thresh  thresh  prob
      0       0/0               0/0              0/0           20      40  1/10
      1       0/0               0/0              0/0           22      40  1/10
      2       0/0               0/0              0/0           24      40  1/10
      3       0/0               0/0              0/0           26      40  1/10
      4       0/0               0/0              0/0           28      40  1/10
      5       0/0               0/0              0/0           30      40  1/10
      6       0/0               0/0              0/0           32      40  1/10
      7       0/0               0/0              0/0           34      40  1/10
   rsvp       0/0               0/0              0/0           36      40  1/10
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 0/88/0
PE
sh policy-map interface multilink 13
Multilink13
  Service-policy input: ip2mplsin
  Counters last updated 00:00:00 ago
    Class-map: mpls5 (match-any)
      1186588 packets, 238359525 bytes
      5 minute offered rate 420000 bps, drop rate 0000 bps
      Match: mpls experimental topmost 5
      Match: ip precedence 5
      QoS Set
          Packets marked 0
    Class-map: mpls3 (match-any)
      29868 packets, 1860988 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: mpls experimental topmost 3
      Match: ip precedence 3
      QoS Set
          Packets marked 0
    Class-map: mpls1 (match-any)
      71240 packets, 3428902 bytes
      Match: mpls experimental topmost 1
      Match: ip dscp af41 (34)
      Match: ip precedence 1
      QoS Set
          Packets marked 0
      250070361 packets, 150310399298 bytes
      5 minute offered rate 496000 bps, drop rate 0000 bps
      Match: any
Customers router is a 2821 running 12.4(11)T
Policy configuration
class-map match-any Signal
match ip dscp cs3
match ip dscp af31
class-map match-any Voice
match ip dscp ef
policy-map Voice-Out
class Voice
  priority percent 70
class Signal
  bandwidth percent 5
  random-detect
class class-default
  fair-queue
270
