06-16-2012 01:08 AM - last edited on 05-14-2023 11:58 PM by Translator
i am trying to achieve a load sharing with cisco 837. The topology is the one showed below:
I want to track each connection so that if for example there is not connectivity through modem/router, this route get deleted from the routing table. So i have created the ip slas:
ip sla monitor 1
type echo protocol ipIcmpEcho 4.2.2.2 source-interface Dialer0
timeout 500
frequency 5
ip sla monitor schedule 1 life forever start-time now
ip sla monitor 2
type echo protocol ipIcmpEcho 4.2.2.2 source-interface Ethernet2
timeout 500
frequency 5
ip sla monitor schedule 2 life forever start-time now
track 1 rtr 1 reachability
track 2 rtr 2 reachability
The first sla is for checking that there is connectivity via ADSL and the second that there is connectivity through the other modem/router (because eth 2 could be up but modem/router has lost internet connectivity)
and then i added two default routes that use the track objects:
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 192.168.1.254 track 2
The result is that the track objects are always down because (???) there is no route for the packets and the debug ip packet commend shows:
s=192.168.1.253 (local), d=4.2.2.2, len 64, unroutable
even though the modem/router is reachable and has a valid connection to the Internet. Does anyone have any idea how i can override this problem?
Solved! Go to Solution.
06-16-2012 04:50 AM - last edited on 05-14-2023 11:59 PM by Translator
Dear,
Can you please verify if the dialer interface is up or not, if its up it must have installed a default route towards dialer interface.
Modify the configs as followed
Modify 4.2.2.2 in IP slap 1 and change it to 4.2.2.1 and leave ipsla2 as it is
Put 2 static routes I.e
IP route 4.2.2.1 255.255.255.255 dialer1
IP route 4.2.22 255.255.255.255 Ethernet 0 or far0/1 or whatever it is
Let me know the outcome.
M
Sent from Cisco Technical Support Android App
Dear,
M
06-16-2012 08:01 AM
Without applying the modification you suggested, even though Dialer interface is up no default route is installed because of track 1 failure. Is this reasonable?
I will make the modification you said and i will cone back...
Thanks for your help.
06-16-2012 11:44 AM
Well not a big problem..once SLAs are up default route will take over..please proceed with the suggested modifications
Musab
Posted by WebUser Musab Kiani from Cisco Support Community App
06-17-2012 05:22 AM
Thanks my friend...Your solution seems to work great. If you have not problem i would like to mane another question. I have read that load balancing may cause some problems with https site (e.g. e-banking). Is there any way to force the specific traffic to follow a specific road (when this "road" ia active) but auto failover to the other exit when the first is down?
06-17-2012 05:56 AM
And something else, does anyone knows why cisco 837 do not support event manager?
06-18-2012 12:55 AM - last edited on 05-15-2023 12:02 AM by Translator
Welcome,
You don't need to worry about that, just make sure the load sharing over both links is per-destination which is default behavior of cef.
Just make sure CEF is enabled. If you don't want to use both links as active active, put AD in the end of the default route you want to use as just fail-over.
You can do
sh ip cef 0.0.0.0/0
detail and verify if the load-sharing is per-destination based or not.
Musab
