Problem with VLAN Going in shutdown mode after power On
I have one cisco switch series 3500 and I am facing the problem with the VLAN.
Once I configured it and saved all the config,and after that If I power off the switch and then again power on the switch ..its VLAN goes in shut down mode.I have rechecked it again all teh config and again made the VLAN no shut..and when Once again I did the same thing power Off and On the VLAN goes again in shut down mode..>can any one please help. It SW version is 12.0(5)WC13.
Silver
Re: Problem with VLAN Going in shutdown mode after power On
Is there any port belongs to that vlan? If not that might be a problem.
yeah we have few port is belong to that vlan
Hall of Fame Super Blue
Can you post config of switch.
Is this switch acting as a layer 2 or layer 3 switch ?
Jon
IT is acting as layer 2.
kindly understand the things from the attached mail ..this is the switch swutc1..
waiting for ur response ASAP..JON
Silver
Are they up or admin down?
It is UP but..see if anytime the power goes off the VLAN goes in shutdown..and again through console we have to log in and we have to make it ..no shut..and it starts working..but again if we power off the switch again it goes in shutdown..then again we have to take to console and make it up
Looking at the configuration file u have attached, i c a shutdown command at the end of the interface configuration
ur config:
interface VLAN2
ip address 10.30.130.101 255.255.0.0
no ip directed-broadcast
no ip route-cache
shutdown
Do a no shutdown to the vlan interface and then copy the config to startup config ... and then reboot ur switch and check ...
hope this helps u ....
as the switch is at customer end I will try this once i go ther and will let you know..
lets see if this works..
214
