Webcast-Catalyst9k
Problems with a NM-HDV2-2T1/E1
I have a 2821 with an NM-HDV3-2T1/E1 network module installed. I have an VWIC2-2MFT-T1/E1 installed in the open slot. The VWIC is connected to 2 data T1s and they are working fine(t1 1/0/0 and 1/0/1). The problem I am having is defining the onboard T1s as data T1s. When I define the controller and the channel group on t1 1/0 ( channel-group 0 timeslots 1-24 speed 64) I get and error message:
%Insufficient resources to create channel group
Here is the controller configs:
controller T1 1/0
framing esf
clock source internal
linecode b8zs
cablelength short 133
controller T1 1/1
framing esf
linecode b8zs
controller T1 1/0/0
framing esf
linecode b8zs
detect v54 channel-group 0
controller T1 1/0/1
framing esf
linecode b8zs
Is there something special I need to do to get the onboard T1s defined for data?
Thanks, Steve
Re: Problems with a NM-HDV2-2T1/E1
hi
i suppose u need dsp in ur router. check how many dsp u have , add more dsp
( u can be sure of this by reducing time stols try "channel-group 0 timeslots 1 speed 64" command , if router take the command u can increase the time slots untill it give u the same error )
regards
Hall of Fame Super Gold
The thing is that "channel-group" does not uses DSP and it is a data configuration, not voice.
This case should be given to the TAC in my opinion.
Thanks for the input. I have opened a TAC case.
hi
I still think this is because of dsp
u can try the method it will hardly matter of 10-15 min after that if does not solve u can go a open a tac case
regards
Let's wait for the answer from TAC to ssjoberg.
Perhaps it will come out that VWIC in the slot on NM-HDV cannot be used for data, although this is not evident from any document.
It should work in an HWIC slot on the 2821, if available.
it will come down to router resources. i have a 3745 with an nm-hdv2 and a 2 port t-1 trunk controller installed and i couldn't turn up the new t-1 on the 2nd port. i maxed out the dsp on the module and even decreased the size of the trans coding and conference config with no luck. i think i need to add memory to the router and not the module. just my $.02.
Hi Jerry,
No it shouldn't be the memory. To create serial interfaces (channel-group), the router needs something called "HDLC framer". It is the device than handles serial communication and it can be located in different places depending the router architecture.
489
