Community Member
Problems with Connecting WAP4410N with 2 SSID to Catalyst 2960-s Switch
Hi all,
Just need some assistance from you guys for the issue as mentioned in the title, I have problems with connecting WAP4410N with 2 different SSID (Staff & Guest) to Catalyst 2960-S series switch.
Devices in hand:
1. One unit of WAP4410N
2. One unit of Catalyst 2960-s Series Switch
3. One unit of Unifi modem (ZTE ZXDSL931) **Specific modem which support fibre backbone
4. One unit of Unifi supported wifi router (D-Link DIR-615) **Supported Dynamic PPPOE Protocol
Connection between devices:
From the image above, I need to create 2 different SSID from WAP4410N (staff & guest).
** Guest SSID will be isolated from all LAN devices.
** Guest SSID will be only allowed to access to the internet.
I had already configure Cisco switch catalyst 2960-s and configuration as below:
** Two trunk port created for the connection from (2960-s to 4410N) and from (2960-s to D-Link DIR-615)
** First VLAN created with VLAN ID 10 and it would carry "Guest" SSID
** "Staff" SSID will use the default VLAN which is VLAN 1.
As the information given by cisco support engineer, Unifi Router (D-Link DIR-615) need to support multiple VLAN subnet.
Unfortunately, D-Link DIR-615 above does not support multiple VLAN subnet.
So, is there any other way i can do to achieve my goal with the existing devices on hand?
Your help is highly appreciated.
