07-31-2013 08:40 AM - edited 03-04-2019 08:37 PM
i am struggeling with my policy maps. I created three class maps, and i want to assign matching traffic to three different output queues on my 2811 router running IOS 151-4.M6.
this are my class maps
class-map match-any REALTIME
match dscp cs4
match dscp ef
class-map match-all BEST-EFFORT
match any
class-map match-all CRITICAL-TRAFFIC
match ip dscp af21
this is the policy map
policy-map WAN-EDGE-TO-PROVIDER
class REALTIME
priority 10240 2048
class CRITICAL-TRAFFIC
bandwidth 20480
random-detect dscp-based
class BEST-EFFORT
bandwidth 17920
then i applied it to the interface
interface FastEthernet0/0
ip address 172.16.137.6 255.255.255.248
ip ospf priority 0
duplex auto
speed auto
mpls ip
service-policy output WAN-EDGE-TO-PROVIDER
I sent packets with CS4 through the router, when i do show policy-map interface fa0/0 it shows only hits in the BEST-EFFORT class but not in the REALTIME class.
Any ideas what i did wrong?
here is the show output as well
FastEthernet0/0
Service-policy output: WAN-EDGE-TO-PROVIDER
queue stats for all priority classes:
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
Class-map: REALTIME (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: dscp cs4 (32)
0 packets, 0 bytes
5 minute rate 0 bps
Match: dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Priority: 10240 kbps, burst bytes 2048, b/w exceed drops: 0
Class-map: CRITICAL-TRAFFIC (match-all)
0 packets, 0 bytes
Match: ip dscp af21 (18)
Queueing
bandwidth 20480 kbps
Exp-weight-constant: 9 (1/512)
Mean queue depth: 0 packets
dscp Transmitted Random drop Tail drop Minimum Maximum Mark
pkts/bytes pkts/bytes pkts/bytes thresh thresh prob
Class-map: BEST-EFFORT (match-all)
10652 packets, 5851955 bytes
5 minute offered rate 1976000 bps, drop rate 0 bps
Match: any
Queueing
(pkts output/bytes output) 10652/5851533
bandwidth 17920 kbps
default 7/495 0/0 0/0 20 40 1/10
cs4 10637/5850350 0/0 0/0 28 40 1/10
cs6 8/688 0/0 0/0 32 40 1/10
thanks in advanced
Alex
08-01-2013 01:37 AM
does it start matching when removing BEST-EFFOR class from the WAN-EDGE-TO-PROVIDER policy-map?
im interested in a solution myself.
08-01-2013 06:13 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Don't know if it's the issue the issue, but in your REALTIME class you're using "match dscp" and in your CRITICAL-TRAFFIC class you're using "match ip dscp". I believe there's a subtle difference between the two versions, but I don't recall what it is without some research.
Also BTW, you BEST-EFFORT class might be replaced by using the class-default class (avoids the need to defined an explicit class).
08-02-2013 08:25 AM
Joseph,
the difference between "match dscp" and "match ip dscp" is that with the keywork ip will match IPv4 packets and without ip, IPv4 and IPv6 packets. So, it should work. However, I would test with match ip dscp to see if there are matches in REALTIME class.
Best Regards,
Jose.
08-04-2013 10:01 AM
Hello Jose,
I tried it with and without the ip keyword. Both times it didn't work. Even removing the Best Effort class helped.
I will Open a tac Case tomorrow and update this discussion as well
Alex
08-04-2013 11:11 AM
Hello Alex
This policy map will only act upon matching dscp values. So do have these values being marked already?
Res
Paul
08-04-2013 12:16 PM
Hello Paul,
I am sending packets from a traffic generator. I sent packets marked with dscp cs4.
Alex
08-04-2013 02:34 PM
Hello
So can you confirm this traffic generator is creating dscp value of 32 (cs4)
Res
Paul
08-05-2013 08:14 AM
Hi Paul,
yes i can confirm. I did couple other tests, i send IP SLAs from a switch behind the router. And it seems the router does not recognize any dscp values from afxx classes. here are my ip sla config
ip sla schedule 140 life 60 start-time now
ip sla 150
udp-jitter 172.22.2.242 17000 codec g711alaw codec-size 160
tos 80
verify-data
vrf NCS
ip sla schedule 150 life 60 start-time now
ip sla 160
tos 88
verify-data
vrf NCS
ip sla schedule 160 life 60 start-time now
ip sla 240
tos 104
verify-data
vrf NCS
ip sla schedule 240 life 60 start-time now
ip sla 250
tos 112
verify-data
vrf NCS
ip sla schedule 250 life 60 start-time now
ip sla 260
tos 120
verify-data
vrf NCS
ip sla schedule 260 life 60 start-time now
ip sla 340
tos 128
verify-data
vrf NCS
ip sla schedule 340 life 60 start-time now
ip sla 350
tos 136
verify-data
vrf NCS
ip sla schedule 350 life 60 start-time now
ip sla 360
tos 144
verify-data
vrf NCS
ip sla schedule 360 life 60 start-time now
ip sla 440
tos 160
verify-data
vrf NCS
ip sla schedule 440 life 60 start-time now
ip sla 450
tos 184
verify-data
vrf NCS
ip sla schedule 450 life 60 start-time now
ip sla 460
tos 192
verify-data
vrf NCS
and here my show policy-map output
Queueing
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
0 packets, 0 bytes
5 minute rate 0 bps
Match: ip dscp cs4 (32)
0 packets, 0 bytes
5 minute rate 0 bps
Match: dscp af21 (18)
0 packets, 0 bytes
5 minute rate 0 bps
Class-map: class-default (match-any)
12135 packets, 2531780 bytes
5 minute offered rate 64000 bps, drop rate 0000 bps
Match: any
Queueing
(pkts output/bytes output) 12135/2531472
default 105/8859 0/0 0/0 20 40 1/10
cs2 3003/630306 0/0 0/0 24 40 1/10
cs3 3003/630306 0/0 0/0 26 40 1/10
cs4 3003/630306 0/0 0/0 28 40 1/10
cs5 2002/420204 0/0 0/0 30 40 1/10
cs6 1019/211491 0/0 0/0 32 40 1/10
regards
alex
08-05-2013 08:48 AM
Hello
I can see tos value 128 which is applicable to CS4(dscp32) - so then does this switch have mls qos enabled and if so is dscp trusted?
You can also use extended ping to create tos:
ping
Protocol [ip]:
Target IP address: x.x.x.x
Repeat count [5]: xx
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]: 128
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
08-05-2013 09:16 AM
Hello Paul,
the switch doesn't have mls qos enabled. I just use it to send data through my router.
regards
Alex
