Process causes high CPU utilization on catalyst 4500
Hello, I have a catalyst 4500 with the CPU utilization nearby 60%, other switches in the same network have less than 10%. I have identified this process as the problem source, but I don't have any idea about how to solve it, someone could help me about this? Thanks.
K2L2 Address Table R
%CPU target = 2.00
%CPU Actual = 17.09
Purple
Re: Process causes high CPU utilization on catalyst 4500
There is a great document on troubleshoothing this issue here:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
You might want to go through that first...
Pls do rate the post if it helps...
Paresh
I already had seen it, but it doesn't say what the process is, anyway thanx.
Any Idea of why this process could reach high CPU utilization?
R4500-LGV#show platform health
K2 Packet Memory Dia 2.00 20.84 15 8 100 500 0 1 0 41:23
In the link below doesn't show any comment about it.
Any hint will be appreciated.
MACh
Is port utilisation is ok or abnormal and any errors on it ?
Rajesh
Monitor to see if there is a pattern of the increase in the process (timing). If it does u need to check for the particular process which is the culprit of the cause.
1012
