Process sequencing
Please,
When you try many process like PBR, NAT, ROUTING, IPSEC, GRE, ARP ETC..
For example i know that nat is running before nat.
I need information about sequence of this process, means the first process , second, third and ... ?
Do you have a document about real sequence for all process ?
Regards.
Re: Process sequencing
i make a mistake, i would like to say that "nat is running before ipsec".
Regards.
Silver
This is a very important concept to understand especially if you want to do un-orthodox tricks with NAT. I am sure you will find the information in this link helpful as it shows the correct order of various processes in both directions; for in -> out and from out -> in:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
i need more information. The sequence is not explain with more detail.
i have a router with this configuration:
RTA:
int e0/0
ip nat in
ip address 196.201.1.2 255.255.255.0 sec
int e0/1
ip nat out
ip policy route-map internet
ip address 192.161.2.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 196.201.1.1 name ISP2
ip nat pool fiber-internet 196.161.2.1 192.161.2.1 prefix-length 29
ip nat inside source route-map internet pool fiber-internet overload
route-map internet permit 5
match ip address 104
set ip next-hop 192.161.2.1
match ip address 103
access-list 103 permit ip 192.168.1.0 0.0.0.255 any
access-list 104 permit ip host 192.168.1.3 any
Is with configuation when 192.168.1.3 try to join internet to go to isp 1 (the nat is take in account)
after translation to 192.161.2.1 (inside global address).
When other host than will use isp 2 with ip address 196.201.1.1 (inside global address)
if it not correct which configuartion i can try ??
Regards.
Silver
Can you please explain what you are trying to achieve and what does your setup look like? I am interested to know how your inside network is connected to both ISPs.
Good day,
the set up i give to you, is an case study.
I want to understand the different step take by router which make nat+PBR like you can see on the exmaple.
Regards.
Silver
Does this case study come with a topology diagram? I am asking for additional details as there are a couple of confusing, and possibly erroneous configuration statements (not applied to the correct interface), in the configs you have put here.
If you provide a link to this case study I can better explain all the steps to you.
252
