03-28-2007 04:22 AM - edited 03-03-2019 04:20 PM
We have 7 location, All locations We wants to connect throught lease line upto 512kbps.
For center site we select these products.
CISCO2811, WIC-2T, CAB-SS-V35MT.
This is right selection na if any thing wroung pls let me know soon.
regds
03-28-2007 04:44 AM
Yes, you can go ahead with this. All the products seems to be inline with the requirement.
HTH,
-amit singh
03-28-2007 04:47 AM
thanks for prompt response, could you brief me how to configure router with lease line.
03-28-2007 04:58 AM
A better option would to be to go with HWIC-4T as it allows you to multilink 4 ports in one card upto 8MBps
THe configuration should be simple. Once the circuit is turned by the provider, assign ip addresses at both ends.
THe only thing to check is the encapsulation type at both ends which should be similar
Narayan
03-28-2007 05:10 AM
Okay cisco2811 hv the 4 HWIC slot, I think WIC2T also support na or it will not.
03-28-2007 05:13 AM
it will support WIC-2t as well on the HWIC slots.
HTH,
-amit singh
03-28-2007 05:14 AM
It supports both.
We follow a standard where we do not multilink across different slot cards and hence when you use WIC-2T u limit the capacity to 4 MB.
But you can go ahead with WIC-2T
Narayan
