prom cookie corrupt on 1841?
I have a Cisco 1841 router that refuses to boot properly: depending on the IOS I try I get different errors or crashes. When I start the router with c1841-ipbase-mz.123-11.T5.bin, I can get to the console prompt. But I get 2 eeprom read errors and an 'Unable to create driver for Port Adaptor' error), and it does not show any interfaces.
It also shows a very unusual 'sh ver':
Cisco 1841 (revision 0.0) with 114688K/16384K bytes of memory.
Processor board ID
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
(notice the wrong revision, missing SN and interfaces)
and sh diag gives a blank output.
When I got to rommon and run cookie I think this showes too many ff values in the first bytes:
rommon 5 > cookie
cookie:
04 ff 09 86 ff ff ff ff ff ff ff ff ff ff ff ff
4f 43 30 39 32 32 30 36 41 50 40 04 1b 41 05 00
82 49 1f ff 05 42 42 30 c0 46 03 20 00 5b 8a 02
88 00 00 00 00 02 04 c6 8a 49 50 4d 37 46 30 ....
I tried removing all wics, erasing nvram, different Compactflash card, upgrading rommon, and a dozen different IOS versions.
Any suggestions?
Anyone
1 REPLY
Re: prom cookie corrupt on 1841?
Though you have mentioned about removing WICS,have you tried booting the box without inserting them ? if you have done this already and since you have tried all possible permutations/combinations the well known suggestion would be to open up a TAC case on this ..
regds
303
