02-18-2010 01:08 PM - edited 03-04-2019 07:33 AM
I'm looking for feed back on what GBIC interface to use for and OC3 connection. Currently the dmarc is only down the hall and then it's the providors equipment till it reaches our other site. From there is another fairly short run from the dmarc to the equipment. Distances of less than 100M in both cases. We've been advised in the past from the provider that we should be using single mode fiber, but as it is right now our current equipment is using a PA-POS-OC3SML card in a 7206 and this has a fairly long distance rating for it. What is considered the distance to work from? From site to site or from equipment to dmarc?
Thank you,
Justin
Solved! Go to Solution.
02-18-2010 03:08 PM
Justin,
PA-POS-OC3SML Packet over SONET 1-port OC3 Single-Mode Long Reach port adapter PA-POS-1OC3 + SFP-OC3-LR1 PA-POS-1OC3 base card plus separately ordered long range pluggable optic
The distance is short enough to use multi-mode, but if one side of the connection is single-mode then on your side you have to use single-mode also.
The fiber type and optic has to match on both sides.
Reza
02-18-2010 03:08 PM
Justin,
Reza
