Proxy-arp issues
Actually I have a Cisco 12008 GSR with GE Line Cards, a GE interface is connected to 2960G switch in mode Trunk which receives diferent Base Stations where Customers CPEs are connected. We have created sub-interfaces per every Base Station, the problem faces when two CPEs connected to the same sub-interface (of course on the same ip address range) can not ping each other or communicate using WAN interface, in some Cisco 2821 we solve this issue applying ip local-proxy-arp command on subinterface. Please if somebody knows a similar command on Cisco 12000 GSR or an alternative solution, I really appreciate your help.
Best Regards
Jackson
  • WAN Routing and Switching
112
