Community Member
PTP link btw sites issue
We have PTP link btw two sites, when we did failover test on the link, the X sites of VLANs were able to reach site Y site. But only one VLAN not able to reach the Y site from X site.
In a N/W cloud, X site hooked with xxxx B/W and Y site with xxx B/W. However the failover PTP link btw these two sites is xxx B/W.
LAN routing protocol is EIGRP.
My only concern is that only only one VLAN not able to reach the Y site from X site. What could be the issue?
Hall of Fame Super Gold
Re: PTP link btw sites issue
A configuration mistake.
Hall of Fame Super Blue
Not sure how you expect us to answer this with the details provided. I would think the most likely culprit would be a missing route for the vlan in site Y so that return traffic cannot get back to site X.
Check your routing tables at both ends of the link to make sure all routes are present. If they are then it would help if you could provide some more details and some configurations.
Jon
146
