Public IP block routed via vpn
My current setup:
I have a cable modem attached to GigEther0/0 and is assigned a dynamic ip address. Local network/switch
is connected to GigEther0/1 and using nat overload. Local network uses the 10.0.0.0/24 ipv4 ip block, GigEther1
has the ip address 10.0.0.1, as well as 2001:470:d:c00::1. I am using a tunnel to accomodate ipv6 traffic
to and from he.
I have a l2tp vpn tunnel setup connecting me to a company supplying me with a /28 ipv4 ip block. My ip assignment
with them is 72.0.227.64/28. The following is the basic config they gave me:
vpdn enable
l2tp-class ACE
hidden
authentication
hostname user@host
password ...
pseudowire-class ACE-PW
encapsulation-class ACE-PW
protocol l2tpv2 ACE
ip local interface GigabitEthernet0/0
ip pmtu max 1500
ip tos reflect
interface Virtual-PPP1
ip address negotiated
ip mtu 1452
no cdp enable
ppp authentication chap callin
ppp chap hostname user@host
ppp chap password ...
ppp direction callout
ppp ipcp dns request
pseudowire 66.114.76.203 11 pw-class ACE-PW
ip route 66.114.76.203 255.255.255.255 GigabitEthernet0/0 dhcp
the tunnel is up and running, GigabitEthernet0/1 also has the ip 72.0.227.65.
Now the question is, how do I route all traffic originating (or being sent to) an
ip in this /28 through the tunnel (and keeping the rest the same... i.e. 10.0.0.0/24
still goes through the nat overload)?
further info for access list, routing:
ip nat source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip access-list standard NAT
permit 10.0.0.0 0.0.255.255
ip access-list standard VPN
permit 72.0.227.64 0.0.0.15
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 deny   any
access-list 100 permit udp any any range 16384 32767
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
and here is my ip routing table:
Gateway of last resort is 68.5.32.1 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 68.5.32.1
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.0.0.0/24 is directly connected, GigabitEthernet0/1
L        10.0.0.1/32 is directly connected, GigabitEthernet0/1
      66.0.0.0/32 is subnetted, 2 subnets
S        66.114.76.203 [1/0] via 68.5.32.1, GigabitEthernet0/0
C        66.114.76.207 is directly connected, Virtual-PPP1
      68.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        68.5.32.0/21 is directly connected, GigabitEthernet0/0
L        68.5.37.193/32 is directly connected, GigabitEthernet0/0
      72.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        72.0.227.64/28 is directly connected, GigabitEthernet0/1
L        72.0.227.65/32 is directly connected, GigabitEthernet0/1
      172.18.0.0/32 is subnetted, 1 subnets
C        172.18.2.46 is directly connected, Virtual-PPP1
      172.19.0.0/32 is subnetted, 1 subnets
S        172.19.89.28 [254/0] via 68.5.32.1, GigabitEthernet0/0
198
