I have a 877 using PPPoA with a /28 public network. For this example lets just say the network address is 217.10.10.0/28 and .7 is used as the GW. Heres a cut down config :
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 5
crypto isakmp key 6 secureME address x.x.x.1
crypto ipsec transform-set DTset ah-md5-hmac esp-3des
mode transport
crypto map mymap 1 ipsec-isakmp
set peer 1.1.1.1
set transform-set myset
match address myacl
int Dialer1
ip address 217.x.x.x.255.255.248
ip mtu 1492
ip tcp adjust-mss 1452
ip nat outside
crypto mymap
interface Vlan1
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
dialer-list 1 protocol ip permit
Questions
1) What is the correct method of assigning the 5 IPs to the Dialer interface do I simply assign them as Secondarys? (I have done this btw and it works, can ping them external etc)
2) I have 5 IPs and I want a different crypto map on each IP, but I can only assign one crypto map to the Dialer which is the GW and have my other pub ips as secondarys (doh!). How do I work around this?
I have the tunnel working atm to my public GW address, but to me this is simply not acceptable since I want more then one Crypto map AND I have paid for a /28 network.
I have searched for quite a bit on the internet, google etc, and can't find jack.
Andrew
My config
encr 3des
hash md5
group 5
crypto isakmp key 6 secureIPSEC address 81.x.x.145
mode transport
crypto map DTmap 1 ipsec-isakmp
description D&T Grantham
set peer 81.149.148.145
set transform-set DTset
match address 151
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
