Community Member
Publishing Issue
Attempting the seemingly simple task of publishing ports 80 and 443 to a web server device on my LAN through a 1700 series.
used the access-list permit...etc etc command and these items show up in the list of ACL entries, however, traffic doesn't seem to be flowing. Does anyone have any advice, I must be missing something like binding this to an interface or actually enabling the rule.
Re: Publishing Issue
When you say "publishing ports 80 and 443 to a web server device" what do you mean?
Do you mean that you want to permit TCP port 80 and 443 traffic to a particular web server?
If so, this traffic should already be permitted on through your Cisco 1700 router unless you have configured and applied an access-list on the router this is currently blocking it.
Is there an existing access-list in place on the router?
To check you can run the following command:
show ip access-list
And if so, what does the access-list look like and which port is it applied to?
To check which port the access-list is currently applied to examine the interface configuration using the "show run" command and look for interfaces that containing an "access-group" configuration.
Community Member
If that is the case, there must be a port forwarding component. Even if all ports are opened, somehow traffic must be directed to a specific host on the trust side..
70
