Q-in-Q
I am interested in having a particular VLAN in two separate sites. I have read a little about it and was wondering if it would be possible to do across a point-to-point DS3 connection. I see a command on my serial link "Router2(config-if)#dot1q tunneling ethertype ?"
Will this command help me do what I want? I just want to be able to have a particular subnet in two different cities where it's not an option to split it.
Hall of Fame Super Blue
Re: Q-in-Q
Jason
If you want to extend a L2 vlan over a L3 routed link then L2TPv3 will allow you to do this -
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
You don't say what routers you are using or what IOS you have. L2TPv3 is not supported on all routers.
Jon
Re: Q-in-Q
Router1:
Model: 7206VXR
IOS: C7200P-ADVENTERPRISEK9-M 12.4(15)T5
Port Adapter: PA-2T3+=
Router2:
Model: 7204VXR
IOS: C7200-ADVENTERPRISEK9-M 12.4(15)T1
Will this do? From what I can see "2-port T3 port adapter" will work (if that's what PA-2T3 is). And it looks like the 7200 series has been supported as of 12.0(21)S.
You wouldn't happen to have a base config for the interfaces, would you?
Re: Q-in-Q
Hello
If your requirement is to span the vlan between different sites Use the dot1d tunneling feature in the switched connected to ur WAN routers.See the link for config details.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swtunnel.html
Hope this helps.
Ullas
Re: Q-in-Q
The way I understand this is that you can't do this across a L3 link. Am I correct on this?
Hall of Fame Super Silver
Re: Q-in-Q
Hello Jason,
you are correct 802.1Q tunneling is a MAN feature provided by a L2 Service Provider, in your case L2TPv3 is the right tool as explained by Jon.
Hope to help
Giuseppe
217
