10-10-2014 05:21 AM - edited 03-04-2019 11:56 PM
Hi dear All !!!
I have C7609 with ES20.
So, I have created QinQ subinterfaces for solve problems with 4094 Vlans.
But when I typed "sh vlan internal usage", I see internal vlan one per subinterface !!!
And really, I cannot create simple Vlan.
----cut !!! ----
interface Port-channel16.322480
encapsulation dot1Q 322 second-dot1q 480
ip address x.x.x.x y.y.y.y
R#sh vlan internal usage | i Port-channel16.322480
1481 Port-channel16.322480
R#(config)#vlan 1481
VLAN id: 1481 is an internal vlan id - cannot use it to create a VTP VLAN.
----cut !!! ----
10-10-2014 06:51 AM
Here's a good link for QinQ
https://supportforums.cisco.com/discussion/9777026/q-q-sample-config
10-13-2014 04:26 AM
Hi Michael !!!
Thank you very much for your answer!
I have read your topic, but I spoke about "QinQ termination" (stacked VLAN processing)
not about selective QinQ. 3750 cannot do it :-(
The QinQ is L2 technology, but "QinQ termination" is L3.
10-13-2014 09:08 AM
Understood. Maybe this link will help you:
http://ccie-in-3-months.blogspot.com/2008/02/7600-esm-20x1ge-7600-es20-testing.html
10-13-2014 11:48 PM
Thank you Mchael !
I began my learning EVC from this blog. It's very nice theme but I have more deep problems.
I'm planing to create more 7K QinQ subinterfaces, but every subinterface create new internal vlan and I have limit 4096 again :-(
