qos bandwidth per ip address
we'd like to configure qos on our router.
Some ip addresses need more bandwidth when connecting to internet.
The config's as follow
class-map match-any a
match access-group 120
class-map match-any b
match access-group 121
policy-map ilimit
class a
bandwidth percent 40
class b
bandwidth percent 20
interface Ethernet0
description to internet
service-policy output ilimit
access-list 120 permit ip host 192.168.0.2 any
access-list 121 permit ip host 192.168.0.3 any
The output of a "sh policy-map interface e0" shows 0 packet for class-map a and b.
class-default has 18347 packets, 2736652 bytes.
the "show access-list 120 | 121" don't show any matches.
Re: qos bandwidth per ip address
i'm going to guess that yo are natting on this router, and I'm not 100% sure, but I'm going to say that nat is taking place before the access list is being applied, so perhaps you could apply an inbound policy marking traffic with a dscp value the set the outbound policy to match on that dscp value. Someone smarter than me would have to confirm about the order of nat being applied before outbound policy is matched though.
Silver
The above technique is called congestion management. From the name you can predict that congestion management policies is applied when congestion happens. Currently you have connected your Ethernet to the internet however do you have an E10 to the internet? If not then the policy won't be effective because it has to wait till congestion happens before it starts policing traffic.
Another thing to note, the QOS usually uses 75% percent of the bandwidth inteface. Therefore, when you mentioned 40% for Class a it means 40% out of the 75% and when you mentioned 20 it means 20% out of the 75%.
The solution to the above is:
Set your interface bandwidth to the same speed of your internet pipe. Therefore, if you internet bandwidth is 2Mbps, go to the interface and issue the command "bandwidth 2000".
As for the QoS reserved bandwidth which is by default 75% you can enlarge it to use the 100% by issuing the command "max-reserved-bandwidth 100".
Let me know if the above helps,
Appreciate your rating,
yes, we're using nat and the port ethernet0 is connected to the internet.
The main problem is that packets are not classified as intended.They are put in class-default.
We'll try what you've suggered and we'll let you know.
Thank you
We've tried the following config.
policy-map p_in
class a
set ip dscp ef
class b
set ip dscp af41
int f0
to LAN
service-policy input p_in
class-map match-any c
match ip dscp ef
class-map match-any d
match ip dscp af41
policy-map p_out
class c
class d
int e0
to the internet
service-policy input p_out
There's no packet on class a, b, c,d.
what's wrong in the config ?
Silver
Can you paste your access-lists? Becuase you should match the private IP addresses in your ACLs.
here are the acls
Silver
What is the your internet pipe speed? Is it 10 Mbps?
I am asking this question because what you are using is congestion managment. This means the policy won't apply until there is congestion.
It's 512KB but it's shared for many clients, we only get about 6KB.
When there's no congestion,what should we get when executing "show policy-map interface e0", traffic should be classified as class a or b or should it classified as class-default?
hi again,
now,it shows packets on class a and b.
when you say
>> Currently you have connected your Ethernet to the internet however do you have an E10 to the internet? If not then the policy won't be effective because it has to wait till congestion happens before it starts policing traffic. <<
do you mean i need to put bandwidth 512?
I have also problem on dimensionning bandwidth to affect per class.I put 40% and 20% for testing.
Could you give any suggestion , please ?
Silver
That's correct, I mean to put bandwidth 512000 on the interface. In this way, QoS will know that your CIR or bandwidth is 512Kbps and when congestion happens it will police the traffic according to your policy.
As for setting the bandwidth for each class, usually QoS is allowed to use 75% of the bandwidth of the interface leaving the other 25% for other protocols such as CDP, dynamic routing etc... So when you set 40% it means 40% out of the QoS resrved bandwidth.
To override the above issue you can set the command "max-reserved bandwidth 100" under the interface and in this way the QoS will consider using the 100% interface bandwidth which is 512Kbps in your case.
In order to assist you in setting the percentage I need to understand what are you trying to acheive.
Let me know how it goes,
The need of bandwidth's as follow, the first listed is the most who need bandwidth:
- voice
- some users works on http.they should have all bandwidth they need.
- The manager should always be able to access internet when they need.they use msn, mail, http.
- some users should be able to send file by ftp.
- all other users use bandwidth not used.
Hi Haddad,
Is there any more information i should give you?
what bandwidth some we attribute per class?
for http, many users use http but only some users should be given priority.
Silver
Sorry for the delayed reply. I have been so busy. Do you want to guarantee these bandwidth all the time or during congestion only?
Let me know your feedback,
Could you tell what to do for each case?
For our current configuration, we've tried what happen with qdm.
connexion seems slow but the bit rate graph are the same for pre and post-policy.
Normaly, bandwidth should be guaranted during congestion
Silver
What type of VoIP are using. This is because VoIP protocols differ from one application and vendor to the other. I have done the below bandwidth division while using LLQ for RTP traffic.
ip cef
class-map match-all VoIP
math protocol RTP
class-map Match-all Manager
policy-map QoS
class voip
priority percent 30
class Manager
class class-default
bandwidth percent 30
interface Ethernet0
bandwidth 500
max reserved-bandwidth 100
service-policy output QoS
The above will guarantee
30 for VoIP RTP traffic
40 for your Manager
30 for all other user's internet traffic
The above policy would only start or take effect when the 500Kbps gets congested.
Please let me know if this solves your scenario,
Thanks for the config, do we need to specify bandwidth for http for only few users or is it unecessary ?
we'll try it and i'll let you know.
what do you use to monitor qos?
Silver
Hope this configuration works as per your requirements. To monitor the effieciency of the policy, try to get the link congested and issue the command "show ip policy interface e0/0" then check the counters and matches.
Remark: e0/0 is the interface where you applied the policy.
We used 2 classes for test.
We've tested qos by launching many download in 2 pcs of different class.
here's the output of show policy-map e0
Class-map: a (match-any)
52886 packets, 3437122 bytes
5 minute offered rate 7000 bps, drop rate 0 bps
Match: ip dscp ef (46)
5 minute rate 7000 bps
Queueing
Output Queue: Conversation 265
Bandwidth 40 (%)
Bandwidth 1 (kbps)Max Threshold 64 (packets)
(pkts matched/bytes matched) 271/20948
(depth/total drops/no-buffer drops) 0/0/0
Class-map: b (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip dscp af41 (34)
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
We've tested different values for bandwidth just for test.
There's no packet drop, no queue depth.
What's the interpretation of the result, how to know if the appropriate bandwidth was affected per class ?
Silver
Can you please the latest Config?
Like your config but we don't have put yet the class voip,we've put another class with acl
policy-map p_in
class a
set ip dscp ef
class b
set ip dscp af41
int f0
to LAN
match ip dscp ef
match ip dscp af41
policy-map p_out
class c
class d
int e0
to the internet
bandwidth 500
Silver
Sorry for not getting back to you earlier. In the above configuration you are just guarnteeing bandwidth for the classes. However, for VoIP it is better to use priority because they require to exit the queue before any other traffic.
As for the show output your policy is taking effect but it didn't reach the stage where it starts dropping packets. Therefore, things looks from the perspective of the show output.
Appreciate your rating and let me know if you need anything else,
Hi Haddad,
We will use the protocol RTP for voip.
It's not yet in use.
What can you say about the output above?
Is there any more information you need?
Silver
If you are going to use RTP then it is better to use the below class.
class VoIP_RTP
match protocol RTP
PLease let me know if you need anything further,
Hi Haddad,
Our problem is that the connection seems so slow for all classes,when we look at the post-policy and pre-policy bit rate, we've got the same graph.it seems as that's there's no congestion.
Is it normal?
Silver
How much is your exact internet pipe?
Let me know,
it's 512Kb, shared, it's not a guarented bandwidth.
While doing the test, we've used many different values for bandwidth.
Silver
It is very tough to do QoS on a shared pipe. This is because you are never guaranteed the bandwidth you've got on the interface. THerefore, the QoS should be based on your guaranteed bandwidth.
That is if your guaranteed bandwidth is 256Kbps you have to base your QoS on this band and not on the 512 because sometimes the ISP would be giving you 256Kbps for example and your router won't know that it has to activate the QoS until it reaches the 512Kbps congestion state. Therefore, your QoS would never queue and drop traffic according to matches.
Hope this helps,
We've also tested qos by using "bandwidth 3" for eth0, we didn't see queued / dropped packet.
How to see if it reaches 3Kbps ?
The thing is congestion first occurs not on your 10Mbps interface, but whatever is the next device (a DSL modem/provider managed CPE?). That's why you don't see queued/dropped packets - they're not dropped by your router, but by next device.
Configuring bandwidth on the interface does nothing to restrict speed of the interface, it's only informational parameter which is used to calculate many operational parameters but it doesn't police traffic. In such situation you need to configure two-level hierarchical QoS - in the parent policy you define traffic shaping to whatever actual access link speed is, then you specify child policy to do CBWFQ. For example:
policy-map MyQoS
class A
band perc 40
class B
band perc 20
policy-map QoS-512
class class-default
shape ave 512
servcie-policy MyQoS
interface Eth0
service-policy QoS-512
Then you'll see queued/dropped packets.
Hope it helps.
2052
