QoS between two catalysts 3750
we are running a transparent 2Mbit L2 link between two sites with a catalyst 3750 on each (connected to a fast ethernet port)
we want to implement qos to priorize 320Mbit for EF and 600 Mbit for AF3.
the EF packets are already marked; the packet for the AF3 have to be marked first.
Has anyone done already a similiar setup?
Hall of Fame Super Silver
Re: QoS between two catalysts 3750
Hello Frank,
if you are using bridging over a WAN link and no L3 device is involved you can try to take advantage of SRR queueing in C3750
>> In shaped mode, the egress queues are guaranteed a percentage of the bandwidth, and they are rate-limited to that amount. Shaped traffic does not use more than the allocated bandwidth even if the link is idle. Shaping provides a more even flow of traffic over time and reduces the peaks and valleys of bursty traffic. With shaping, the absolute value of each weight is used to compute the bandwidth available for the queues.
see
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swqos.html#wp1200681
the shaped mode should be the one that fits your needs.
you need to configure appropriate marking on ingress interfaces
Edit:
with routers you could use hierarchical QoS shaping all traffic to 2 Mbps and invoking a child policy with a scheduler.
with C3750 switches you may be able to find only an approximate solution
Hope to help
Giuseppe
Hi Giuseppe,
thanks for your answer. It confirms the results of my "studies" that the 3750 is not the most flexible platform for QoS.
regards
frank
127
