QOS ,CCTV
waeelahmed
my Question is  if i have 1 MB link and want to allocate 512 Kbps for the CCTVSystem and 512 Kbps for the Data on cisco router how will be the configuration for that ?
Joseph W. Doherty
What kind of link?  1 Mbps physical or logical?  What IOS version on the router?  Do CCTV hosts mark their traffic?
MPLS link.IOS version is 12.4
Your router's interface is configured for MPLS natively?  Link is physically Ethernet?  So the 1 Mbps is a logical limit?
What release of 12.4?  (QoS features were greatly enhance in the later 12.4 releases.)  Answer to my CCTV is marking question?
Vishesh Verma
Yes you can reserve bandwidth for video and data traffic on a cisco router using class-based-queuing. However, first you need to define/segregate your video traffic from the data.
You can use Cisco NBAR feature to do that or if your CCTV is marking the TOS byte of IP header then you can classify based on that as well.
http://www.cisco.com/en/US/docs/ios-xml/ios/qos_conmgt/configuration/12-4/qos-conmgt-cfg-wfq.html#GUID-9003885B-51B6-436B-9825-4804E51DCE53
http://www.cisco.com/en/US/partner/docs/ios-xml/ios/qos_nbar/configuration/12-4/qos-nbar-12-4-book.html
Note : -  Cisco ISR routers do not support queuing on Etherswitch-Modules
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/prod_white_paper0900aecd8064c9f4_ps380_Products_White_Paper.html
